Creaking Panoramic Roof
Old Jun 11, 2019 | 01:27 PM
simonptaylor's Avatar
simonptaylor
Any else have this issue, my dealer has replaced the guide rails twice and it's still the same, super freaking annoying as it gets worse and worse over time. Had enough with the dealer trying to fix this. Any suggestions ?
Old Jun 11, 2019 | 02:23 PM
smokewagun's Avatar
smokewagun
On my 2016, it did the same.
The cure was to clean BOTH the seal AND the metal painted surface in contact with the seal. Once clean, put spray silicone on the seal. Be protective of the paint. I used a rag to cover the over spray from the can’s straw. Just don’t need it all over the roof.
I did this once every 6 months, and never heard a peep. Prior, it drove me nuts.
Old Jun 11, 2019 | 06:21 PM
KJ Smith's Avatar
KJ Smith
Above may work.
I used the same process and silicone grease on the seal instead of silicone spray.
Good for a year or so.
On Edit: I assume you are talking about the creak from the glass while driving and not a noise made while operating.
Old Jun 13, 2019 | 07:09 AM
simonptaylor
Thanks all for the replies, yes the glass/frame seems to creak over every bump, the dealer says its because the guide rails are broken but they have replaced them twice and it's still the same. I just assumed the glass roof just don't fit that good or is a bad design. I love the look and the light it provides but it's bull on a truck which I spend 70K on.
The roof works/functions fine
17 F150 Limited. 3.5Eco 4x4 3:55
Old Jun 13, 2019 | 09:29 AM
smokewagun's Avatar
smokewagun
Try the recommendations by myself and others. It’ll likely go away.
Old Jun 13, 2019 | 05:22 PM
KJ Smith's Avatar
KJ Smith
I may try smokewagun's method next time (soon).
May be easier to spray silicone on a rag and wipe it on.
The grease can be a little messy.
Old Nov 15, 2019 | 06:26 PM
KJ Smith's Avatar
KJ Smith
I had to do this again a couple of months back.
This time I used dielectric grease ( silicone).
Worked great, easy to apply, a little thinner than what I used before.
So far its the best I have tried.
Old Nov 15, 2019 | 08:49 PM
GlueGuy's Avatar
GlueGuy
DC4 or something like that?
Old Nov 15, 2019 | 10:24 PM
KJ Smith's Avatar
KJ Smith
Loctite LB 8801 5.3 oz tube.
https://www.rshughes.com/p/Loctite-L.../079340_51360/
Old Nov 16, 2019 | 11:16 AM
Joe T's Avatar
Joe T
If you want a pic of the Ford stuff they used on my 2019 I can try to get one later. There is a TSB on it. They gave me a tube.
Old Nov 16, 2019 | 11:24 PM
KJ Smith's Avatar
KJ Smith
Please.... and Thank You.
Old Nov 17, 2019 | 01:55 PM
smokewagun's Avatar
smokewagun
Yes, please advise what they gave you. I’m interested, too.
Old Nov 19, 2019 | 12:14 PM
David W Jones's Avatar
David W Jones
Ford recommends Krytox 205. I bought a tube off of Amazon and follow the sunroof cleaning TSB about once every 6 months or so. My pano roof (fingers crossed) works quietly and flawlessly. There is a TSB (16-0020) outlining how to lube it. It takes about 10 minutes. https://www.f150forum.com/attachment...tsb16-0020.pdf
Luch
Oct 17, 2013 03:43 PM
78150custom
Oct 1, 2011 08:29 PM
hxgaser
15
Jul 8, 2011 12:54 PM
hoxiii
Apr 21, 2008 04:40 PM
packrat56
Jan 11, 2006 11:35 AM
