Distributor Issues
1. Replacing your module with a red grommet California module
2. Replace coil with Ford square coil (1984-1997)
3. Bypass or delete resistor wire that feeds coil +
This system will retard advance when starting, adjust dwell under load, provide a very hot spark all while maintain stock appearance
I managed to do this spending only $30.
There are other small reasons why I prefer this to the GM ignition such as Ford distributor caps provision for an air vent which reduces cross fire/miss fire due to ionization of air inside cap. Also, Ford uses a much taller rotor which also helps prevent misfire and degradation of cap. Also GM put the module 1.5 inches away from the high secondary voltage of the coil, --one spark to ground through the module and you're walking home.
Nevertheless, HEI is still good, but this is better!
Coil: FD-478 https://www.ebay.com/itm/Ford-Mazda-...frcectupt=true
Maybe Mr. NumberDummy could provide us with the actual Ford engineering numbers to better locate parts.
Since you already have the large cap/rotor and 8mm plug wires you should be good to go. Pop some iridium plugs gapped to .045 and you'll have a HOT ignition. Of course, you're distributor pick up could be bad, but fortunately that part is the same regardless and relatively cheap.
You are also going to need to replace the coil-to-cap wire with a certain female-female type as the square coil has a male post unlike the old cylinder style. Maybe Mr. Numberdummy could also help determine which year to get that from? I want to say 1985-1996.
Check ignition coil for resistance primary to primary should be 1.5 ohm. Pri to sec should be 10k ohm.
Lay a spark plug on intake, exhaust manifold or other solid metal grounded piece and crank. Do you see spark? If not --> Pull center wire off cap and hold it 1/4 inch from ground while cranking. Do you see spark? If not measure, coil for 9V.... You'll soon find out where the problem is.
Check all connectors, grounds, etc for cleanliness and tightness. Inspect cap and rotor for damage, plug condition etc....
Sometimes a wire breaks inside the insulation and intermittently fails when it gets bumped the wrong way... lots of potential causes here. I had a truck that would refuse to start for no rhyme or reason and sometimes die while driving. Turns out the coil connector was damaged and barely contacting... easy fix once I found it.
As discussed earlier, top suspects are 1. pickup 2. module 3. coil and 4. bad wire/ground connection
I received my pickup coil and got it installed last night. The install went well and she fired right up. Took a spin around the block to get the engine warmed up, and it appeared to be running great. As I was pulling back into the shop, the truck died and wouldn't start again... SO, next on my list is the ignition module.
I've been scouring the internet this morning and haven't found any GENUINE motorcraft modules. Do I have no choice but to get one of the Chinese ones? Is my best option to buy 2 of them at the local parts store so I have a spare?
1. Check proper operation of choke
2. Adjust carburetor to baseline setting
3. Check for vacuum leaks all over
4. Possible reason is the ant-diesel throttle kicker solenoid, due to emissions, these carbs were set-up in such as way that had the throttle plates completely closed when engine off, requiring power to throttle kicker solenoid to open them to a baseline level. Is your solenoid present and working? --This can also be adjusted.
Overall, when chasing gremlins in 45 year old carbureted vehicle, it is best to have everything tuned-up and in good condition, otherwise you are flying blind. Are plugs, cap, rotor, wire, battery, fuel filter, and carburetor in good shape? -- Sometimes a carb rebuild does wonders.
I rebuilt the carburator when I got the truck, still couldn’t get it to run so I brought it to a shop to have it rebuilt (a few years ago), then it started fine until now.
I’ve searched for vacuum leaks multiple times before, and while I am willing to bet there is at least one (maybe more), I haven’t found any.
I’m running out of steam with this thing
I didn’t try that yet. It’s a good place to start though.
