351M Starter Woes
So, after some searching on the Goolag and here, I've found nothing specific to my issue but a whole lot of confusing information. The most common replacement starters appear to be listed as 351M/400/460 etc. which apparently isn't exactly correct. Also, many of the new style mini-torques have a solenoid attached to the starter body? Not sure how that jives with a stock solenoid setup.
Any advice from the demigods of dentside?
Pictures related.
351M corroded starter lead
I have recently replaced the starter on my 351M. If you end up removing the starter (which migh help you with this situation) note that the bottom bolt faces the rear of the truck but the top one goes in through the back and faces forward.
Good luck!
If it fits, and is proper for the engine/trans, it can be wired to work.
Keeping the starter relay/solenoid on the fender is the best way to do it in fact. Keeping the old relay not only gives you a convenient spot to mount all the extra wires out of harm's way, and takes some of the additional load off of the ignition switch (a real solenoid pulls a few more amps than even a big relay like we have on the fender), but also serves to isolate the starter motor from the electrical system so it can't backfeed and keep the starter running longer after you let off the key.
It does not do that every time, but it's still better to retain the relay. And yes, Ford calls it a "relay" and not a solenoid like most of the rest of the world has learned.
The method of connecting it then goes like this:
1. Battery cable stays where it is on the fender mounted relay.
2. Starter cable (a NEW one in your case!) is relocated to the battery side.
3. The new wire that you make yourself, or that might come with a starter if you buy a retrofit kit from one of the vendors, runs from the (now empty) starter side of the relay, down to the starter's "S" post on the solenoid.
Assuming that the solenoid was wired complete out of the box, you're done and working.
Or you can keep the old starter style if you prefer, and leave it connected the old way.
Either way works.
Paul
Looks like yours are decently sized (maybe 4ga?) but changing one is always a good opportunity to up-size them again. I like 2ga because they're readily available at most parts stores, reasonably priced (just a couple of bucks more than 4ga I think) and heavier duty is better up to a point of overkill.
And for me, overkill is just enough!
Anyway, I consider larger battery cables to be cheap insurance against melt-downs and other mischievous things.
I actually use 1ga and 1/0ga on my trucks, but would gladly use 2ga any day if I had to. I just have lots of heavy welding cable and like to make my own cables sometimes.
But unlike many, I actually like the parts store cheapies too. I always "customize" them by putting some shrink tubing (preferably the sealed type) over the junctions between the outer jacket and the end terminals. Seals them off and lets them live longer lives.
Paul
https://www.amazon.ca/Industrial-394...12949473&psc=1
Good luck!
Either way works.
Paul
Paul
Got the old starter out with a 24" and 18" extension and generous amounts of WD-40 penetrating oil. The old wire was definitely not coming off as it was.
Replaced the cable and solenoid while I as at it. Should last a few years, with luck!
Man, that old wire was never going anywhere again. It was already under-sized for the normal world, but add some stress and it really shows it's weakness.
The new one should be a huge upgrade.
Glad it's cranking. Is it up and running too?
Paul
Paul
I'm almost done with the essential wiring (ignition system) and will be happy once she's running. My punch list includes dropping the gas tanks (using a boat tank for now) and running new lines, sending units, and switching valve. Brakes and tires as well as new soft goods and shocks. I'll also need a new power steering pump as the old one leaks badly. I've been eyeing the Saginaw upgrade kit for my 351M but I'm also considering a total serpentine setup to ditch the triple stack V-belt setup on my rig.
Then there's the interior...
I can see a 351W motor as it is a bigger 302 and share the same parts most of the time but from what I know the 351M & 351C are different motors from the 351W motor.
I could also be wrong as I am not up on the 351M & 351C motors.
Dave ----
Most of those from the aftermarket for other engines are prohibitively expensive for most of us however, so I keep looking for junkyard donors that could be made to fit with the least amount of fuss.
My go-to for the 5.0/5.8 engines is the Explorer, which I have in boxes now, but have not had time to see what trickery would be involved in getting it to work on a 335 engine.
Paul
Can you throw it on a charger overnight? Or did you already do that?
Paul
But regarding the starter applications, what's not correct about that? The 460 does in fact use the same starter as the 335 series at least overlapping several years.
From engines built in Dec of '76 until the end in '82 the 351M and 400 engines used the same starter as the '77-'92 460's did. (at least in trucks).
A "solenoid" by definition does some mechanical work, whereas a relay simply closes electrical contacts (it's just an electromagnetic switch). So the piggyback thing is a solenoid because it physically moves a lever that kicks the drive gear into the ring gear. It also happens to close a switch contact, but it's no longer just a relay because of the lever arm and gear function.
Many people choose to upgrade to the newer style (called PMGR for "permanent magnet, gear reduction) because they use less energy to turn the engine over slightly faster. And they sometimes sound more like a modern car, and some of us think that's cool too. Nothing scientific, just a feeling of hanging with the cool kids.
It's been touched on of course, but so you know there is no such thing as a 400M engine. Only the 351's have letter designations to differentiate between the three common versions (W, C & M).
Ford didn't do us any favors on that account by always listing them as 351M/400 because it seems putting them together like that almost guaranteed we think of them with the same letter. But it was just that they were the same engine except for the crank and rods (and maybe pistons) so they did not separate them often.
Correcting someone is definitely a nit-picky kind of thing, but some of us just want to make sure to keep the knowledge alive.
Only the Windsor lasted long enough into the modern era to have Ford design serpentine setups around them. And like the others, they use the same cylinder heads (virtually) and same block architecture, so lots of parts interchange among the 289, 302 and 351W.
The C, the M and the 400 are all members of the "335 Series Engine Family" and use the same cylinder heads and some other engineering characteristics. Other than that though, the Cleveland is narrower, shorter, has smaller main bearings and a shorter stroke and was probably designed mostly for performance cars and for higher rpm work in a more compact package. The M's were in big cars that needed more low-rpm torque and strong bottom ends. The Cleveland and Windsor and 400 were released within just one or two years of each other too, with the M coming along a little bit later from basically de-stroking a 400 and creating yet another Ford engine with the 351ci displacement. So things were happening fast in the '68/'69/'70 era.
Basically then, the M and the 400 are literally both the exact same engine block and heads, and the only thing that makes one larger than the other is the length of the stroke and (I think) the connecting rods. They are both physically larger than the Cleveland sibliing (even though of similar design), but were still used in passenger cars as well as in later years, the trucks to '82/'83 or so. The Cleveland died relatively quickly though, in what, maybe '73 or so? I still remember the first time I saw an M engine and told the guy, "hey, you've got a Cleveland in your truck!" not knowing any better at the time.
All the differences aside, you can actually bolt up Windsor heads to 335 engines. Bore spacing and bolt patterns are the same. Somewhat like what Ford did with the Boss 302, which had a variant of the Cleveland heads on it.
For this reason when people start using "small block" and "big block" designations for Fords, the 335's get wedged into both categories. They look big, and in fact kind of are, but with Windsor bore spacing, they're more small than big. Just heavy-small...
Other small variances were 351W's had larger bottom end and main bearings and larger diameter head bolts. And even headers and intake manifolds would directly swap over between a 302 and 351W depending on which block they were mounted to. Lots of people swapped Windsor heads back and forth over 289, 302 and 351W engines over the years. Same for 351C engines, where someone might want the smaller ported and valved "2bbl" heads, vs the more race-ready "4bbl" heads from the factory. Most modern heads are based off the smaller 2bbl version though, because few people run their 335's to 8,000 rpm except for someone with a Pantera or whatever. Anything on the street benefits from the smaller ports of the 2bbl "Cleveland" heads.
Sorry, lots of fluff for little benefit. But I was bored and it's Saturday and I like talking about this stuff!
If I made any mistakes in the details, sorry 'bout that.
If you made it this far... THANKS!!!
Paul
I've got the battery on a charger and I'll see if it can top off around 12.5-13Vdc. Might pull some jumper cables out if I have to.
I'm not sure if I might have my timing off? I can hear the clicking as the coil discharges to fire the plugs, and my timing light blinks around 15° (ish!) but I haven't even got a pop or backfire to show for things.
Thanks!
