New radio with Door AND Dash speaker?
I'm going to be putting in a single DIN radio in the 77, with new door speakers as well.
I've read a lot of threads in here (very helpful) on experiences doing so, but I do have 2 questions.
1. Is there a "go-to" technical thread done by anyone on the full scale new wiring in of a new modern single DIN radio and speakers? I've gotten tidbits here and there from other threads, but I can't seem to find one as an authority.
2. Is it possible to have the radio wired into both the 2 door speakers AND the in-dash center speaker?
Thanks everyone!
Thanks everyone!
I am wiring my truck with a NOS AM/FM MONO radio just so I can pick up the FM stations. My truck came with an AM radio and only the dash speaker. I know a lot of the guys have said that you need to make sure you match the speaker OHMs with your radio, so you don't do damage to your radio.
With a MONO radio, I don't see why I (personally) couldn't do what you are talking about BUT, I am not sure about your radio.
IOW... a lot of variables.... so there may not be a thread like you are looking for here.
Maybe start a thread and list your specifics and ask for advice (??).
If it’s purely a two-channel stereo radio, it’s possible, but more trouble than it’s worth. To do it properly, you’d need a bridged amplifier for the center speaker, with its own gain control so you can adjust its volume separately from the door speakers. Simply bridging the radio’s stereo output will end up with an out of phase signal and could damage the radio’s amp.
Unless your radio already has a center channel built in, I’d leave the dash speaker alone. You could also wire it to a CB, or an AUX input with a small dedicated mono amp. In a truck cab, having a center speaker won’t really make that much difference to the listening experience, so you should only use it if it’s easy.
You could get a dual channel speaker from Custom Autosound or the like, and put that in the dash location. Presumably your new head unit has provisions for 4 speakers, run the front outputs to the dual speaker in the dash and the back outputs to the speakers in the doors.
https://customautosoundmfg.com/product/dual-speakers
I used a Custom Autosound stereo the P.O. installed but I installed a set of component speakers in the doors, I also put the foam cup behind them, makes them sound better and protect from elements. Not sure if you like the idea, but I put the Custom Autosound Undercover II behind the seats, they sound great, wish I could have but them under the seat but custom brackets prevent that, but they should fit under a standard bench. Now I can blast the tunes
The P.O. had the dash speaker and the drivers side door speaker set as the front left and right and the passenger door as the rear left, no rear right.... It sounded like total garbage. Also had the + & - reversed on some of them causing the volume control to spaz out...
on
on
Lots of stereo stores sell them. They are like these.
https://www.amazon.com/Install-Bay-S...s%2C202&sr=8-5
5 1/4” bolt right in, 6.5” takes just a shade of trimming in the doors - one that I bought had a pair of 4” mounted under the old center grille, basically a poor mans dual channel. Looks like it fit pretty nice, PO used a couple strips of flat to mount em. Those 2 along with the door speakers actually sounded quite good ( I’m not an audiophile, though). Simple wiring and pretty loud for no amp or anything.
