vin decode
Old Jun 8, 2019 | 08:33 AM
hello113's Avatar
hello113
vin decode
run across a 66? f350 with a dump box motor runs sort of and the dump box works no brakes but it does have a seat I could use
anyway kinda like to know what it is
thanks mike
Old Jun 8, 2019 | 08:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hello113
Ran across a 66 F350 with a dump box, motor runs sort of and the dump box works, no brakes but it does have a seat I could use.
F35 = F350.
Y = 352 2V
K = Kansas City MO Assembly Plant.
771302 = 1966.
132" Wheelbase.
A = Raven Black.
F350, 10000 lbs. GVWR
N81: N = Red Crush Vinyl & Red Cody Pattern Woven Plastic // 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
22 = Dana 70 Rear Axle / 4.88-1 / 7,400 lbs.Rear Axle Capacity.
10,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
63 = Memphis TN Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Jun 9, 2019 | 06:11 PM
DAJATO's Avatar
DAJATO
Is there a way to look up a 64 F100’s data if all I have is the VIN? I can’t find a data plate on the door area and the glove box has the remnants of a tag of paper on the inside. VIN is:
F10- F100 2WD
C- V8 292-2v 135hp@ 3800rpm
E- Mahwah NJ
493406- 64 model year in sequence
I was told it was a NC School Bus maintenance truck (it was SB Yellow at one point). It is a SWB and has a Custom Cab instrument cluster and Custom Cab door handles. Any help is welcome, I’m at the end of what I can think to research.
Dan
Old Jun 9, 2019 | 06:31 PM
NumberDummy
VIN: F10CE493406
F10-= F100 2WD
C = 292-2V does not decode to: 135hp @ 3800rpm
E = Mahwah NJ Assembly Plant.
493406 = 1964.
Dan
If the Warranty Plate is missing, you're out of luck. Ford THREW AWAY all the records for 1961/66 trucks decades ago.
It may be possible to reconstruct the missing Warranty Plate, but you'll have to do the research for the missing info.
1st line: Warranty Number (VIN): F10CE493406
2nd line: WB: / COLOR: / MODEL: / BODY: / TRANS: / AXLE:
3rd line: MAX GVW LBS: / CERT NET HP: 135 / RPM: 3800 / DSO:
Old Jun 9, 2019 | 07:01 PM
DAJATO's Avatar
DAJATO
Thank you for the info, I have my shop manual out and now have some additional research ideas. Won’t be able to find all info as the truck has been modified before I bought it. Gotta love a 55yo vehicle!
baileybilt
Indiana Chapter
Dec 2, 2019 05:48 AM
edbee
Apr 28, 2014 09:42 PM
old uhaul
Vehicles for Sale
Feb 13, 2013 12:43 PM
Elvis40
Vehicles for Sale
Apr 8, 2011 07:42 PM
MichaelG
Apr 14, 2002 09:17 PM
