'76 Dash instrument cluster question
I also want to add some small led strips inside the dash to make it much brighter than it is now.
Any help is appreciated!
Thanks, Jon
PS I love this old truck
My suggestion is to get the parts to fix your original cluster and get after market gauges if you want them.
I am sure others will chime in with specifics.
Besides the gauge cluster itself with its appropriate pigtail, you will need an oil pressure sender in place of the oil pressure switch. For the ammeter I purchased a stock ford ammeter that was converted to a voltmeter by Rocketman.
Using the year correct wiring diagrams I re-pinned the old idiot light cluster wires according to the new gauge cluster pin outs..
In my case I wired the former ammeter leads into seatbelt warning position of the new cluster. I even replaced the red seatbelt plastic bezel with my red ammeter plastic bezel so that it illuminates correctly when I start the vehicle. I wired my new Rocketman voltmeter direct with two new leads that were outside of the pigtail harness. My old ammeter leads were positioned into the seat belt illumination locations on the new gauge cluster pigtail .
Effectively I have a voltmeter with separate wires outside of the harness in the stock dash location and an ammeter idiot light in my seatbelt light position.
It really wasn't difficult but more finicky. You must be certain of the model year of the both the trucks harness AND the Gauge cluster/pigtail because there are year to year differences.
Thanks
tbruz
1979 with WARNING LAMPS uses a different printed circuit board than 1976/78's with WARNING LAMPS. 1975 printed circuit boards are 1975 only. 1973/74 are different.
D9TZ-10K843-A .. Printed Circuit Board - Use with Oil/Amp WARNING LAMPS / Marked: D9TF-10C956-AA / Obsolete
1979 F100/350 & Bronco // 1979/86 Econoline.
D6TZ-10K843-C .. Printed Circuit Board - Use with Oil/Amp WARNING LAMPS / Marked: D6TF-10C956-CA / Obsolete
1976/78 F100/350 & Econoline // 1978 Bronco.
D6TZ-10K843-B .. Printed Circuit Board - Use with Oil/Amp GAUGES / Marked: D6TF-10C956-BA / Obsolete
1976/79 F100/350 // 1976/91 Econoline // 1978/79 Bronco.
this site is great - you guys rock!
Thanks
tbruz
