Your dealer should have replaced the APIM because more than likely that’s why it’s acting this way and it’s a known issue to most if not all dealers. Laggy touch screen response is a common issue with a bad APIM and it’s usually one of the first symptoms to show up.
The APIM is what’s attached to the back of the display screen and it’s essentially the brains of the SYNC system.
100% this is the APIM module. Has the same issue for months, fixed by dealer. I made reference to the issue I had on your youtube vids. Hope all gets solved !!!
