Cracked LED tail light
Old Jun 4, 2019 | 02:46 PM
Ryanc3055's Avatar
Ryanc3055
Angry Cracked LED tail light
Driver side anyone know of any in junk yards 650.00 oem is high
Old Jun 4, 2019 | 03:01 PM
Fordplatty15's Avatar
Fordplatty15
$518 is a little better.
https://parts.autonationfordwhitebea...al--tail-lamps
Old Jun 4, 2019 | 03:17 PM
Turbo Dog's Avatar
Turbo Dog
Ouch! If it only has a crack put some tape on it and forget about it.
Old Jun 4, 2019 | 04:10 PM
Poncho450's Avatar
Poncho450
Depending on size of the crack, I'd fill it with some type of fast setting clear glue/epoxy while I searched around for something a hell of a lot cheaper than $650. Or $518 for that matter.
Old Jun 4, 2019 | 04:48 PM
BlackOps450's Avatar
BlackOps450
Swap both for around same price with recon
Old Jun 4, 2019 | 04:51 PM
GABAR's Avatar
GABAR
Ebay for a used one or Fairway Ford on Ebay for a new one.
Old Jun 4, 2019 | 05:36 PM
PlanoRob's Avatar
PlanoRob
Odd, my driver’s side taillight cracked too. Nothing has ever touched it other than the car wash whips. For $500, it looks like I’ll keep that crack, too.
Old Jun 4, 2019 | 08:03 PM
tickpop's Avatar
tickpop
4wd Low
when mine cracked I had a brief fit and then a large fit when I heard the replacement cost so I fixed it with a tube of super glue and its been fine for over a year now.
Old Jun 4, 2019 | 08:13 PM
Xwild's Avatar
Xwild
There are a bunch of us with cracked right ones. I know mine has been cracked for at least - most of the time I've had it. It may have come cracked - it's hard to notice, until you know it's there. Never has gotten any worse in 28k miles and 3 winters. So it's staying right there.
Old Jun 4, 2019 | 09:00 PM
2017-350's Avatar
2017-350
I've got a set I'm looking to dump cheap PM me
Old Jun 4, 2019 | 09:09 PM
RenoHuskerDu's Avatar
RenoHuskerDu
Isn't there an issue with water getting into the LED tail lights and causing serious anomalies that are apparently unrelated?
Old Jun 5, 2019 | 07:14 AM
Ryanc3055's Avatar
Ryanc3055
Thanks for the info going to try the glue thing
Old Jun 5, 2019 | 08:05 AM
HRTKD's Avatar
HRTKD
Gorilla Glue makes a clear repair tape that I've used to patch things on my RV with good results.
Old Jun 5, 2019 | 11:37 AM
Yecats's Avatar
Yecats
2017-350...Tried to PM you.
Old Jun 6, 2019 | 09:57 PM
Aaron S's Avatar
Aaron S
What's up with the $80 core charge? Would I get that back if I sent them an assembly with a cracked lens? Its not like this is a water pump that can be rebuilt I wouldn't think.
Mine is the right side also.
