Trailer plug issue
Old Jun 3, 2019 | 08:18 PM
tazawoo2006's Avatar
tazawoo2006
Trailer plug issue
I do not have any power going to my 7 way plug on the RT & LT turn signals. Have replaced both fuses and relays. Any help would be appreciated as this did not fix it.
Old Jun 4, 2019 | 07:49 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Have you opened the 7-way on the truck to check for corrosion? Do you have a voltage tester? Start at the fuse and continue until you find the break. Next post. include your year truck.
Old Jun 4, 2019 | 05:28 PM
tazawoo2006
This is what i found and it fixed my issue. FUSE #100 was my particular fix.
In the cab fuse box, you will want to check fuses 13, 14, 15, 30, 31. All of these are trailer fuses that are 15A
According to your 2014 Ford F-250, the fuse number 26 (30A) is trailer tow park lamps. You will also want to check relay 29 for trailer tow park lamps. Fuse number 70 (10A mini fuse) is for trailer tow backup lamp and relays 74, 75, 76 are for trailer lights. You will want to check fuse 100 (25A) for trailer tow turn signals. Finally relay # 102 is for trailer tow battery charge. These fuses and relays are in the power distribution box in the engine compartment.
Kyle Campbell
Dec 17, 2015 09:09 PM
tjworker
6.7L Power Stroke Diesel
May 28, 2015 07:59 AM
adamsre
2009 - 2014 F150
Jun 24, 2011 08:12 AM
XNrepair
Mar 19, 2010 12:23 PM
Hotairjunkie
Electrical Systems/Wiring
15
Jul 21, 2009 11:49 PM
