Trailer wiring issue?? Help!!!
Old Jun 23, 2011 | 01:30 PM
adamsre's Avatar
adamsre
Ok, I just bought a brand new 2011 ecoboost F150 FX4 with tow package (TBC, 7 pin etc..). My interior trailer lights would not work when connected to it and truck running (or off). My electric trailer jack would not work either. Now, if I hooked up my wife's toyota everything worked just fine. My local Ford dealer was clueless and wanted me to drop it off for a few days.
SOLUTION:
There were two items that were in the glove box a pink fuse and a black relay. They go under the hood in position #9 & #21. Fixed!!!!!!!!
Old Jun 23, 2011 | 07:44 PM
johndeerefarmer's Avatar
johndeerefarmer
Thanks.
That is fairly common knowledge and posted about quite a bit around the forums. if your dealer didn't know that by now you need to hunt another dealership for your service work.
Oh BTW, it is a fuse and a relay, not two fuses.
This applies 12V to your RV and or the electronic trailer brake away controller to keep its battery charged.
Old Jun 24, 2011 | 06:45 AM
michael cook's Avatar
michael cook
tw
look in your fuse panel spot 9 is a relay spot 21 is a 30 amp fuse if there not there then that is your problem and the fuse has to be the real short one or lid will hit it good luck
Old Jun 24, 2011 | 08:12 AM
adamsre's Avatar
adamsre
Originally Posted by johndeerefarmer
Thanks.
Yeah, I know! I was just keeping it simple (black relay #9 and pink fuse #21) just in-case someone else had the same issue. I read the entire manual and those fuse/relays were not mentioned. I read the tow section and the fuse charts. I checked the plug but what threw me off was the turn signals and running lights were working just fine. I thought I had a factory defected truck. lol
Ryan Skipper
All Things Towing
Nov 13, 2021 06:12 AM
Biggziff
Oct 21, 2020 09:53 AM
Aufgeblassen
All Things Towing
21
Jul 14, 2014 05:39 PM
metriccar
Mar 25, 2012 04:37 PM
BobbyDiesel71
All Things Towing
Sep 13, 2006 09:02 AM
