Clogged cowl - SOS!
Old Jun 3, 2019 | 03:34 PM
Redrokin09's Avatar
Redrokin09
Clogged cowl - SOS!
This truck has sat under a pine tree for the past 10 years, The vents on top of the cowl are completely clogged up, I opened the lower flap coming from the heater and I have all kinds of debre in there. It's going to take days to clean it all out. So, my big question is this. Is there a way to access the cowl to get all of the crap out?
Old Jun 3, 2019 | 03:37 PM
Redrokin09's Avatar
Redrokin09
You can see the pine needles picking out, my OCD isn't liking this.
Old Jun 3, 2019 | 05:04 PM
azroxx's Avatar
azroxx
I pulled out a rubber grommet under the fender. My fenders were off at the time tho. I literally pulled out a gallon bag full of leaves and then blew down into the cowl vents with an attachment on my air blower and an equal amount came out the hole. Mine was an oblong grommet, halfway down the fender.
Old Jun 3, 2019 | 05:11 PM
Redrokin09's Avatar
Redrokin09
Thanks for the info, I will take the fender off if I have to. This is crazy. It's not good, it traps moisture and causes rust.
Old Jun 3, 2019 | 05:27 PM
smle's Avatar
smle
I took the fresh air vents off and used a wet-r-dry shop vac. Cleaned everything up good. E-brake peddle need to be moved out of the way to remove the drivers side vent.
Old Jun 3, 2019 | 07:48 PM
Redrokin09's Avatar
Redrokin09
Well.... that was a success. Removed the rubber plug above the firewall. What I couldn't get, the pressure washer took care of. Luckily no big rust spots under it all.
Old Jun 3, 2019 | 07:59 PM
azroxx's Avatar
azroxx
cool!! Happy for ya bud, another checkoff on the list!!
Old Jun 3, 2019 | 08:37 PM
Redrokin09's Avatar
Redrokin09
Thanks for your help, my carburetor will be ready tomorrow. I have another order coming from LMC. I'm just replacing these things as I find them.
Old Jun 3, 2019 | 09:06 PM
fordguy2100's Avatar
fordguy2100
That's a slippery slope lol
Old Jun 3, 2019 | 09:08 PM
Redrokin09's Avatar
Redrokin09
It sure is, my wife asked me last night. How much you spent so far?.... I'm like... ummmm, well.... I need to add up some thing's, she says. So like $400? Oh yea honey. That's sounds about right. 😓
Old Jun 3, 2019 | 09:29 PM
caravaggio2000's Avatar
caravaggio2000
Is there any good way of preventing this (other than parking somewhere else)? My truck is a oak leaf magnet.
Old Jun 3, 2019 | 11:04 PM
mark-guiver's Avatar
mark-guiver
https://www.ford-trucks.com/forums/1...ht=cowl+screen Here's a link to a discussion from about a year and a half ago. See post # 19 for pics my solution.
Mark.
Old Jun 3, 2019 | 11:53 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Mark.. you really a mark-guiver. That is an awesome idea, thank you. I'll post a pic in case folks can't get to the link.
Old Jun 4, 2019 | 07:49 AM
caravaggio2000
Yes! Something like that is what I was thinking about. I wonder how fine of a mesh is too fine.
On this topic... I've been trying to find some kind of paint sprayer that has some kind of line at the end with a head that sprays in all directions, to spray some kind of rust preventative down inbetween things that aren't easy to reach. Anyone ever seen such an item?
Old Jun 4, 2019 | 08:03 AM
77&79F250's Avatar
77&79F250
Take a piece of thin copper tubing or 2 or 3' of brake line, bend over the end and hammer flat to close it. Drill 3 or 4 holes clear thru near that closed end. Flare the other end and connect to sprayer. Like a long reach air tube.
As far as finer mesh, hard part is the install, thru the slits and then security. The 1/4 wire has some flex for install then then flex back with zip ties to go back in a flat shape. I am sure there are other good ideas to secure it with something other than zip ties. Like black zip ties and remember, he said once tight the rotated around the zip head to be on the bottom.
