351w to 351m swap in an 85 bronco
Just wanted to get some thoughts here. I decided to swap my clapped out 351w for a 351m I rebuilt. Decently large cam, aluminum intake, Holley 750 double pumper, mid length headers, gear drive timing. Behind it I had my big block c6 built to hold abt 500 horse w heavy duty borg warner parts and a boss hog 2500 stall converter. Feed back?
It’s not a forever thing. I’m 18 and in college, so I’m working with what I got. Eventually I’d like to move up to a blown 460, but that’ll be awhile
I think it would be cool. It’s taken a lot of work including making custom motor mounts. I’ve searched and searched and never seen anybody swap a 351m into these newer truck. I get because the motor wasn’t the greatest ford ever made, but I figured I had it and I’d try it. It’s an experience and it shows that it can be done, even though others told me it wouldn’t work
I have a 351M in my truck and have been driving it as a daily for almost 7 years now. I cammed it, edel intake, edel 1406 carb, headers and mild exhaust, 3g alt, efan, 4" lift, 33" tires, stock C6, and stock axle gears. I get just under 10 mpg. I am also very light on the right foot. Hopefully this will give you an idea of what to expect. I am the opposite, I want a 351W. Cheaper parts and usually better mpg.
I can understand the possible advantage going to the W motor......however I doubt it would ever produce the torque and HP of the M/400 without more money. My brother had a 79 with a 400 with a crane cam and it was a "hoss" ! If you research parts list you can probably come up with ford mounts/parts to install a M/400 in that frame. I once put a 460 w/c6 into a 69 galaxie 500 XL that had a 390 using ford frame brackets and mounts, so It can possibly be done. The issue will be how close the 85 frame is to the 79 frame so you can use the frame pads for the motor mounts. LMC still shows the 400 motor mounts and I think (last I saw anyway) they show the frame mounts for the 79. If the frames are not too much different that might work. If I had the time, I would do a 400 w/alum heads, retro roller cam, FI and the E40D tranny------in a heartbeat !
