A/C help
Old Jun 5, 2019 | 12:21 PM
  #31
Hit Man X's Avatar
Hit Man X
Thumbs up
I would not be scared of a fully plastic one, my 1998 Volvo V90 had one fully made of plastic...lasted nearly 15 years. Cheap piece of ****.
Old Jun 5, 2019 | 01:04 PM
  #32
sandymane's Avatar
sandymane
This is the only hose that T's off of the heater hoses. I assume this where I should install the heater control valve? Sandy
Old Jun 5, 2019 | 01:14 PM
  #33
subford's Avatar
subford
No not that one.
The hose to your left.
Right above your index finger.
Old Jun 5, 2019 | 01:28 PM
  #34
sandymane's Avatar
sandymane
I assume you are talking about the heater hose itself not the hard line I am pointing at. If so there is no T from the previous picture to the firewall as was pictured in your diagram.
Old Jun 5, 2019 | 02:00 PM
  #35
subford's Avatar
subford
Yes the heater hose. I did not post an image of a Coolant system "T".
The "T" in the diagram above is a Vacuum "T".
But you might want to "T" (use) the white vacuum line as it is in a more handy place.
Old Jun 5, 2019 | 02:13 PM
  #36
sandymane's Avatar
sandymane
Sorry about the misinterpretation of the diagram. Yes a T near the vac line is a much better place to install. Thanks again for your patience and help. Sandy
Old Jun 5, 2019 | 02:59 PM
  #37
Hit Man X's Avatar
Hit Man X
Thumbs up
This will help!
Old Jun 5, 2019 | 03:11 PM
  #38
sandymane's Avatar
sandymane
Originally Posted by Hit Man X
This will help!
Yes it does. Thanks Eric. Sandy
Old Jun 6, 2019 | 02:34 PM
  #39
sandymane's Avatar
sandymane
Got the heater valve installed and the vac line to T off. The heater valve had an arrow on it and I put it in the direction of the firewall. Vent temp is now close to 40*. Everything seems to be fine and working good. I also had to use the Motorcraft valve since the metal one was not available. Anyone see any issues? Sandy
Old Jun 6, 2019 | 07:14 PM
  #40
PRIMERED79 SHORT BED's Avatar
Looks good to me.
Old Jun 6, 2019 | 07:29 PM
  #41
I like the simplicity of yours, here is what mine looks like.
Old Jun 8, 2019 | 02:45 PM
  #42
CamoF-250's Avatar
CamoF-250
I’m using that one too and I don’t really like it. It does work, at least it reduces heat over all at the heater core but I still have flow through it.
Old Jun 8, 2019 | 03:05 PM
  #43
sandymane's Avatar
sandymane
I was getting close to 40* at idle today with mine. It's working great. Sandy
dive2663225
Apr 18, 2018 10:00 AM
mushman
18
Aug 3, 2015 07:54 AM
tjc transport
Jun 13, 2011 08:37 PM
lasitter
May 14, 2010 06:55 AM
gthbryce
Sep 10, 2009 06:45 PM
