A/C help
Old Jun 4, 2019 | 04:51 PM
'89F2urd's Avatar
'89F2urd
Originally Posted by Hit Man X
55F driving is good to you? Those temps are garbage, sorry.
Yea, actually, under certain circumstances 55 would be good. But hey, if we are gonna throw all variables out of the window then I'll play along. It's garbage.
Old Jun 4, 2019 | 06:17 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Neat, sounds cool.
Old Jun 4, 2019 | 06:21 PM
'89F2urd's Avatar
'89F2urd
Neat, sounds cool.
I totally concur!
Old Jun 4, 2019 | 10:00 PM
PRIMERED79 SHORT BED's Avatar
I would recommend after you get your a/c figured out to do this mod.
I had the valve sitting on my self for months and finally got around to installing it, it does help keep the air cooler.
Old Jun 5, 2019 | 07:08 AM
sandymane's Avatar
sandymane
https://www.youtube.com/watch?v=KQ57nIQ05ug&t=186s
Thanks. I have read about the mod and it sounds good. What valve is he/ you using? Sandy
Old Jun 5, 2019 | 08:06 AM
subford's Avatar
subford
You just need to cut the supply heater hose going to the heater and install a standard Ford heater control valve.
Ford has put this valve on on F-series trucks and vans.
You do not have to cut the return hose and with the valve closed there will be no flow in the heater.
Example:
Amazon Amazon
Old Jun 5, 2019 | 08:22 AM
sandymane's Avatar
sandymane
[QUOTE=subford;18690363]You just need to cut the supply heater hose going to the heater and install a standard Ford heater control valve.
For has put this valve on on F-series trucks and vans.
Example:
Amazon Amazon
Perfect. Thank you subford. Sandy
Old Jun 5, 2019 | 08:43 AM
subford's Avatar
subford
Note Ford used the Blue Vacuum Line for the Heater control vacuum motor.
Old Jun 5, 2019 | 08:55 AM
sandymane's Avatar
sandymane
So I should install the valve after it T's off?
Old Jun 5, 2019 | 09:46 AM
subford's Avatar
subford
Yes, the vacuum motor controls the valve.
Old Jun 5, 2019 | 09:50 AM
sandymane's Avatar
sandymane
Thank you. Sandy
Old Jun 5, 2019 | 09:59 AM
Example:
\https://www.amazon.com/Motorcraft-YG.../dp/B0065USF6K
I should of used this one instead, just cut one hose instead of both.
Old Jun 5, 2019 | 10:11 AM
  #28
sandymane's Avatar
sandymane
That's what I thought after I saw the video you sent. Either way is going to work but simple is better for me. Sandy
Old Jun 5, 2019 | 12:03 PM
  #29
Hit Man X's Avatar
Hit Man X
Thumbs up
I used the Motorcraft YG136, went this way as it has some metal on it.
Mine just taps into the recycle blend door vacuum pod (aka Max AC) only. My euro cars dating back to the '70s cut off coolant flow to the core when on Max AC, too. Nothing to worry about. Even a 3-6F further drop from the vents is substantial and noticeable.
Keep us posted if/when you do it. My 88 is getting one when I remember to order one.
Old Jun 5, 2019 | 12:15 PM
  #30
sandymane's Avatar
sandymane
That YG136 looks more substantial with all the metal and it is about 4.00 less on Amazon.
Thanks Hit Man X. Sandy
