6 volt flasher
Old Jun 1, 2019 | 08:57 AM
jvmcc's Avatar
jvmcc
6 volt flasher
Right after I rewired my 53 (6-volt, positive ground) my factory turn signals worked great. They flashed at a reasonable clip. Then, even though I made no additional changes to any wiring or lamping, it started flashing very slowly.I'm assuming that the flasher has crapped out, but I was wondering if there was something in particular that I should be looking for when I buy another one. The one that is so slow was bought through one of the after-part suppliers and was supposed to be the right one for my application.I'm just curious if anyone else has dealt with a similar issue and if I should be looking at specific amperages, etc. If the soundness of the electrical connection might be an issue, then I guess the first place to look for a problem might be at the contacts in the turn signal switch..
Old Jun 1, 2019 | 09:59 AM
Mixer man's Avatar
Mixer man
I know this may not help you, but turn signals are required by law to blink at a rate of 60 to 120 times a minute. One solution would be to install an electronic flasher, as they don't require a load to operate.
https://www.ledlight.com/flasher-6-v...caAsa_EALw_wcB
Old Jun 1, 2019 | 08:35 PM
hooler1's Avatar
hooler1
Very dumb question here. Are all of your turn signal bulbs good? I had flashers go to a slow rate and it just turned out to be a burned out bulb.
Old Jun 1, 2019 | 11:09 PM
abe's Avatar
abe
I have noticed that on my 55F350 the 4 ways flash faster than the turn signals. There are two separate flashing units.
HVACTOM
Feb 14, 2015 04:33 PM
davidw221
6.7L Power Stroke Diesel
15
Oct 7, 2014 04:29 AM
plowking
Electrical Systems/Wiring
Dec 2, 2008 07:14 PM
kdl
1997 - 2003 F150
Sep 13, 2004 10:55 AM
greenterror
Apr 9, 2004 06:58 AM
