Help with flashing dash lights
I have everything working (head lights and turn signals and flashers) but have an issue. When the ignition switch is on, both turn signal indicator lights on the dash gauge cluster and the high beam lamp on the dash flash on and off together . This happens without any other lights or signals on. Just power up the ignition key switch and the dash only flashes. Truck has both standard turn signal circuit and emergency flasher circuit option. I have sourced the correct flasher units (Used number dummy's post about the correct OEM flasher part numbers) and same problem.
The Ford alternator was rebuilt and upgraded with a solid state regulator. That eliminated the separate voltage regulator on the inner fender
I have the wiring diagrams and am tracing circuits but can't find where the system is picking up voltage from the flasher circuit to those three lights at the same time.
Looking for suggestions.
Thanks
Convoy Driver
I change out electrical items as a matter of course, on a new vehicle - a waste of money, you might say, but 50+ year old vehicles need it. Yeah, I am more parts-swapper, than mechanic, but I’ve got the manual and can manage to get most things done myself -if I choose to.
I got my current 66 last year in January. It had spent more than a decade not being used much. We live in a rainy climate. I have replaced the ignition switch, 1-speed wiper switch, wiper motor, horn relay, w.w. pump, alternator,any and every rusty piece of electrical equipment under the hood. I installed a Pertronix module, plugs, wires. I want to change out the dash light voltage regulator. I also have NOS or good used genuine Ford spares for most of these.The last electrical problem to cure is of my own making- I allowed myself to buy the aftermarket fuel sender (read:Chinese) when an NOS was available. Now, I just received the NOS one to replace it, which I should have done a year ago. I do not mind spending money on the truck, it is old, we rely on it, using it every day for our business.
Sometimes the wiring diagrams in the factory manual are incomplete, or not the best. There are alternative ones available, laminated in plastic, I think. Were available for my 59, should also be for Slicks, and I found it on EvilBay.
Hope that helps someone in the future.
Convoy Driver
