Installing a Tachometer Gauge
Old May 31, 2019 | 02:49 PM
1977_f10028's Avatar
1977_f10028
Im installing a Tachometer Gauge, I know where all the wires need to go. I just don't want to run the red wire (power) to the main battery is there a fuse that I will be able to connect it to so I don't have to go all the way to the battery in the engine compartment?
Old May 31, 2019 | 06:45 PM
440 sixpack's Avatar
440 sixpack
You want keyed power. easiest way is to take it off the fuse block under the dash. test to find a slot with keyed power and put a spade terminal in the fuse holder or just splice with a keyed wire.
Old Jun 1, 2019 | 09:26 AM
JakeHan's Avatar
JakeHan
Keyed hot from under the dash (fuse panel or the accessory plug, male bullet terminal) and dash lights, same type accessory plug only yellow (maybe that's backwards). For the signal, I traced the wire back close to the firewall grommet and tapped into it there rather than running it all the way down to the coil, I don't believe it's a resistor wire or anything, it seems to work fine.
Old Jun 3, 2019 | 08:55 AM
niko20's Avatar
niko20
Connected mine to the radio power wire
alchemist1
Aug 15, 2014 08:51 PM
Steve_250
25
Jun 28, 2005 04:56 PM
kwc27
1983 - 2012 Ranger & B-Series
Oct 9, 2004 08:33 PM
Bunggo
Jan 3, 2004 07:46 PM
airharley
Electrical Systems/Wiring
Feb 5, 2002 01:43 PM
