95 F150 302 Code 212 help!
Old Jun 17, 2019 | 10:50 AM
tscholz2001's Avatar
tscholz2001
Originally Posted by rla2005
What you describe is perfectly normal in my book.
Really? I wouldn't have known as I used to have really bad issues with pinging before I fixed it, you think setting the timing back to stock would change anything if this is completely normal? Thanks for all of your help BTW.
Old Jun 17, 2019 | 12:38 PM
rla2005's Avatar
rla2005
You can try bumping the timing back to 10 BTDC to see what happens. No harm in trying, but as I previously stated the pinging may get worse. Running higher octane fuel may mask the issue. Slightly lower timing will most likely be cheaper in the long run if running 10 BTDC results in increased pinging.
ErrorS
1978 - 1996 Big Bronco
Apr 20, 2011 10:33 PM
mikeep
Oct 13, 2008 07:51 PM
brent41m
Jun 3, 2007 10:50 PM
cougar86
Feb 3, 2004 10:56 PM
vincejr
Jan 23, 2004 09:31 AM
