Sponsored by: Real Truck
Check coolant
Old May 29, 2019 | 12:34 PM
gabbie07's Avatar
gabbie07
Check coolant
I have a 2012 250 and yesterday the check coolant additive light came on while driving. Now it comes on when I first turn the switch on and I press OK and it goes away and doesn't come on anymore until the truck is turned off and started again. I have checked both coolant tanks and they are right on the mark and the truck is not running any warmer than usual. I would like to know has anyone else had this issue and what the problem was. Thanks for your input.
Old May 29, 2019 | 12:59 PM
Deuce40s's Avatar
Deuce40s
The warning is a pre-programmed timed reminder, it's not telling you anything is specifically wrong. Read your owner's manual about checking the condition of the coolant. The coolant has specific properties and additives that degrade over time and the truck reminds you to test these properties. There are coolant test packages you can purchase. You can clear the message by going into the settings where you clear out your oil change messages.
https://www.ford-trucks.com/forums/1...tive-info.html
Old May 29, 2019 | 06:32 PM
gabbie07's Avatar
gabbie07
Deuce I appreciate that, thanks...
Old May 30, 2019 | 11:03 AM
geekwithoutacause's Avatar
geekwithoutacause
The additives are pretty important in a diesel coolant. Some of them prevent cavitation. I thought the newer additives are so good it doesn't need to be changed or added in a long time.... not sure. But do check it !
lwk362393
6.7L Power Stroke Diesel
May 7, 2014 06:21 AM
RussB
21
Apr 8, 2014 12:08 PM
Canadian F250
Nov 3, 2012 02:15 PM
jadel
Mar 21, 2005 12:32 PM
