yeah they are just Maxi Fuses, I have a puller for them but you can wiggle them out with a screwdriver or some pliers, But ya really don't need to pull em to check em, just measure voltage on both sides to know if it is open or not... a 12 Volt test lamp is really handy for this.
Connect Black meter lead to Ground then Probe the little metal tabs in the top of the fuse ..... IF there is 12 Volts on one side then there should be 12 Volts on the other side too... IF not then the Fuse is Open or Blown.
