AC gets warm at low idle
Until this morning when I adjusted the AC clutch air gap, my truck's AC was mediocre at best when it cooled at all. It was relatively cool until the engine got up to operating temp, and then it would randomly get warm, and eventually it would get cool again. Low rpm's always caused it to get warm faster.
Since I did the air gap mod, it gets very cold and stays cold as long as the truck is moving. At stop lights I notice a subtle rise in temp that reverses as soon as I hit the gas pedal; not much change in comfort level. It did get warm and clammy sitting in a parking lot eating lunch.
When I got home I put the gauges on it without shutting down the engine and here's what I got at idle: Low-pressure 27psi, high-pressure 180psi. This at roughly 85 degrees ambient temps.
Is this simply a low charge issue? Old compressor not working efficiently? Bad radiator fan clutch?
I imagine the answer is really obvious to anyone with a thorough understanding of AC systems. Thanks in advance for any advice!
Also, on the way home I noticed a droning sound coming from the vents. It was very subtle on AC with the fan on level 3, definitely noticeable with the fan on high, and almost nauseating on MAX AC with the fan on high. I wonder if this is the recirculate door not closing/opening completely.
Received 3,114 Likes
on
The clutch was new two years ago when I converted it to a 7.3L manual clutch. Maybe I'll put the stock electronic clutch back in and see if it makes a difference. At the very least I'll have two fewer recurring trouble codes.
on
My location is Texas. We've already had mid 90 temps. I changed my thermostat three weeks ago because ECT at idle was below factory @186. I don't think its the fan clutch, but I'm going to switch it out just to satisfy my curiosity. I may charge the ac system before going through the trouble though.
Get the gauges hooked up with the truck in your driveway. Insert a thermometer into the center vent. Record pressures and temp while output is still comfortable. Run it at idle until you notice the outlet temperature no longer maintaining a comfortable temp. Record pressures and temp again. Grab your garden hose and spray the condenser with cold water for a minute. Report resulting pressure and temperature behavior.
