2002 E350 pull & shake
Old Jun 12, 2019 | 12:01 PM
Speedwagon98's Avatar
Speedwagon98
Those dirty MFers. I went in to put the adjustable bushing in that I ordered. Turns out, I already HAVE adjustable bushings. The alignment shop didn't bother to look!
So I'm about to head back over there, and make them fix this. From what I could tell, the driver's side was adjusted incorrectly for caster. I put it where I think it should be, and going to make the shop correct it to be right now. I specifically asked them about adjustable bushings when I was there the first time.
Old Jun 12, 2019 | 03:00 PM
Speedwagon98
Wow. They didn't listen to me. Guessed at where the caster should be. Turns out I got it to 5.1 at home, with a good bit of negative camber. Drove straight though to the alignment shop. They turned caster down to 4.1 to get the camber green, but then it was pulling left again. So they are doing it again, 4th time. Told them get at least 5.0 caster, and camber as close to zero as possible.
When I drove it here though, I didn't feel it shaking over 70 though. So that's a good sign.
F-WhiteThunder
Apr 7, 2015 01:07 PM
mechelement
16
Sep 23, 2011 07:39 AM
2000Ford2000
Mar 6, 2011 10:23 AM
Supercab
Mar 14, 2009 04:22 PM
longboardguy
Oct 28, 2008 08:44 AM
