1996 f150 help
Old May 27, 2019 | 04:05 AM
Kencole76's Avatar
Kencole76
1996 f150 help
I have a 1996 f150 with a 6 cylinder engine.
I have replaced the fuel filter.
I have replaced the fuel pressure regulator.
I have replaced the fuel relay
But I am still having an issue with the truck.
This is what I am dealing with.
1. At random times the truck will not start unless I leave the key or ignition switch in the on position for about 1 or two minutes.
2. At random times and without notice it will shutter or stall when driving sometimes it will die and I will have to cost to the shoulder and start it back up.
Sometimes it just stalls but doesn't die.
I can't figure out what would cause this and sence it doesn't do this all the time it is hard for a shop to diagnose.
I would appreciate any help I can get.
I have duel tanks it does this on both tanks.
So I don't believe it could be the fuel pump unless both pumps are having the same problem.
Fuel pumps are expensive so I am exploring all the least expensive possibilities first.
HELP PLEASE......
Old May 27, 2019 | 09:19 AM
Edgethis's Avatar
Edgethis
Check the battery cables were they connect to the battery. They corrode inside and can cause the vehicle to lose power, if bad just grab a new set of terminals from the auto store. They're about $10.
Next, turn the key so the lights come on and jiggle the key around a little bit. See it the lights flicker or you have any issues. Could be a worn ignition cylinder.
Have you had the battery and alternator tested? Most auto stores do this for free.
Old May 27, 2019 | 11:26 AM
byronbgs's Avatar
byronbgs
Pull the computer out and check for bad capacitors. They will have a bubble top or leaking out the bottom. Usually the fuel pumps will run continuously with the key in the run position. The pumps should "RUN" for a few seconds then stop.
Old May 27, 2019 | 12:44 PM
Edgethis's Avatar
Edgethis
You've replaced a bunch of parts on the fuel system. Have you checked your fuel pressure to verify the pumps are working properly?
There is also a fuel pump cut-off switch , that could be causing an issue.
https://www.ford-trucks.com/forums/1...ff-switch.html
ffbaver
Jan 4, 2017 10:31 AM
petepope2336
May 11, 2016 05:50 AM
frankenstein f-150
Oct 19, 2009 06:32 PM
barndude
Electrical Systems/Wiring
Nov 6, 2004 09:34 AM
beaudreaux
Mar 17, 2004 09:01 AM
