Cool Down Time
Old May 26, 2019 | 11:05 AM
f350ktm's Avatar
f350ktm
Originally Posted by rewillia
Per the Ford Owner's Manual; under the section on Starting/Stopping the Engine;
SWITCHING OFF THE ENGINE - 6.7L DIESEL
Switch the ignition off.
To help prolong engine life, we recommended you allow the engine to idle for three to five minutes, especially after any of the following:
  • Continuous engine speed.
  • High ambient temperature.
  • High GVW or GCW operation, for example heavy loads or trailers.
This allows the turbo charged engine to cool down.
http://www.fordservicecontent.com/Fo...userMarket=USA
I follow this recommendation but the times it is indicated are few.
For those especially concerned about cool down I would recommend using turbine temperature for what dictates shut down rather than time.
On my '02 7.3 I installed the ISSPro Turbo Temp Monitor ISSPRO TURBO TEMP MONITOR
This device senses when the pre or post turbo temp drops to a given level (usually 300 degrees) then shuts the engine down. The truck can be locked and with ignition off and doors locked with keys out during the cool down period.
I believe it would take some adaptation to use it on a new 6.7.
Personally I don't feel this device is needed for the 6.7 which has turbine cooloing that the 7.3 did not have.
Old May 26, 2019 | 03:41 PM
CBEllis's Avatar
CBEllis
Originally Posted by RONMCHUGH
I use my CTS2 to monitor egt's and it doesn't display below 392 , so I let it idle until it reaches that and shutdown .
Bingo - you took the words right out of my mouth.
natpark
Aug 9, 2018 07:21 PM
1989f250IDI
24
Dec 26, 2012 04:05 PM
blackeyed1
6.4L Power Stroke Diesel
13
Apr 21, 2012 06:51 PM
61 uni
33
May 11, 2009 02:00 PM
MikeSDK
27
May 31, 2007 01:21 PM
