Interchangeable Parts
Old May 24, 2019 | 10:52 PM
copper76's Avatar
copper76
Which parts are interchangeable between 1973-1979?
Old May 24, 2019 | 11:05 PM
wyrm73's Avatar
wyrm73
Can you be more specific? There are a lot of interchangeable parts depending on what you are looking for. Body parts, engine, etc?
For a quick start, most body parts interchange between years with little or no modification (except front grilles). Engines were either straight six or FE engine from 73-76. The straight six continued 77-79, but the V8s were 335 series (351M or 400). Interior parts and glass swap pretty much between the whole range.
Old May 24, 2019 | 11:08 PM
copper76's Avatar
copper76
Hoods and tailgates
Old May 24, 2019 | 11:12 PM
wyrm73's Avatar
wyrm73
Tailgates good for any 73-79. Hoods interchange for all years too except the 78 & 79 have the FORD letters on the hood rather than the grille.
Old May 25, 2019 | 04:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by copper76
Hoods and tailgates
Hood is the same: 1973/79 F100/350 & 1978/79 Bronco / Styleside tailgate is the same 1973/79 F100/350.
Front fenders and front doors are the same: 1973/79 F100/350 & 1978/79 Bronco.
When new sheet metal was purchased from Ford, there were no holes for mouldings/nameplates.
Old May 25, 2019 | 07:38 AM
copper76's Avatar
copper76
Thanks for all the help.😁
Old May 28, 2019 | 09:38 PM
four-sixty-power's Avatar
four-sixty-power
78-79 Bronco tailgates have window glass in them so don't get one of them for your pick up truck.
Tailgate latch on box attaching screws are phillips #4 if yours are missing and need to find them in a junkyard.
78-79 Hoods also have relief holes cut into them underneath so as to bend better in a crash.
Aftermarket at that time, and maybe still today, there was a tailgate assist bar that could be installed to make closing the tailgate easier to lift up.
If you get a tailgate round cup mount off a newer ford truck up to 96 it will not be a round cup but a sort of slot, which if you cut bottom of tailgate in the same manner of newer tailgates then you can remove tailgate without unbolting the mounts when you want to haul a longer camper or stuff that an open tailgate would interfere with, there are posts on here about it if you search.
75ExplorerF150
Jan 4, 2004 03:28 PM
Gwilkrrs
Sep 25, 2002 02:39 AM
