Engine dies!
Old May 24, 2019 | 05:55 PM
pbsdaddy's Avatar
pbsdaddy
Engine dies!
I have an issue, I'm not sure I have an answer for. I went to a huge "cruise-in" this past weekend and was stuck in some very heavy traffic. Along with the engine heating up, it died on me. A twist of the key did not good. At first I thought vapor lock. But, after only about 5 minutes and increasing engine heat, it did start right back up. I now think it may be a matter of the mechanical fuel pump not supplying enough fuel, at extended idle. I have no problem with electric fuel pumps, but can't see any reason to swap, if that probably isn't the issue. Does anyone have any other ideas? It did not cough and sputter, it just stopped. Much like I had turned the key to off.
Old May 27, 2019 | 09:30 AM
alloro's Avatar
alloro
I had this same issue once when vacationing in Florida. It turned out to be the ignition module stopped working when it got too hot.
Old May 27, 2019 | 05:56 PM
pbsdaddy's Avatar
pbsdaddy
Thanks. I was beginning to think, since so many had viewed but no one responded, I was on the right track. So, did your IM have a circuit breaker built in? How did you discover the problem?
Old May 28, 2019 | 04:36 AM
alloro's Avatar
alloro
No there was no breaker, the electronic components were just overheating and shutting down. The module was external to the distributor so to verify the module was the issue I poured water on it to cool it down and the engine started right up.
Old May 28, 2019 | 11:09 AM
xlt4wd90's Avatar
xlt4wd90
Alloro, are you describing the TFI type of module and distributor combo? That type was known for failing due to overheating because it was bolted to the body of the distributor. That does not appear to be the type that PBSDADDY has on his engine.
Old May 29, 2019 | 08:41 AM
alloro's Avatar
alloro
I don't know exactly what he has, all I'm doing is giving him something to check based on one of my past experiences.
Old May 29, 2019 | 05:18 PM
pbsdaddy's Avatar
pbsdaddy
Mine is a converted GM distributor HEI!
Old May 30, 2019 | 01:27 AM
xlt4wd90's Avatar
xlt4wd90
If you can find another HEI module, try that out to see if it helps the problem.
Old May 30, 2019 | 07:27 PM
pbsdaddy's Avatar
pbsdaddy
I may know where another can be located. A friend has a similar set up.
So, not one thinks it might be a fuel pump issue? That's good, I guess. I can save that much while testing the HEI anyway.
Old May 30, 2019 | 11:32 PM
xlt4wd90's Avatar
xlt4wd90
We're just trying to eliminate the ignition module as the cause right now.
Old May 31, 2019 | 06:26 AM
pbsdaddy's Avatar
pbsdaddy
Sorry, didn't mean to sound like I was disagreeing. The module actually fits the situation better than a fuel pump. There was no sputtering or any other indicator fuel was low.
Old May 31, 2019 | 09:55 AM
alloro's Avatar
alloro
A fuel pump tends to act up more when there's less than half a tank of fuel. So if the fuel level is not a factor in recreating this issue then you can pretty much rule it out for now.
Old Jun 1, 2019 | 12:31 PM
xlt4wd90's Avatar
xlt4wd90
No worries.
Usually fuel pump issues show up when you're under load, and it can't keep up with fuel delivery, but they can usually keep an engine idling.
MDiorio107
Sep 3, 2023 08:02 AM
Reiki
38
Apr 19, 2017 06:57 PM
rgnprof
15
Sep 4, 2013 04:21 PM
bulldogcountry1
Sep 21, 2009 10:57 AM
psquare7575
Sep 19, 2007 06:09 PM
