Check engine
Old May 24, 2019 | 11:46 AM
Edd505's Avatar
Edd505
Check engine
I keep getting the same CEL and the code indicates crank case ventilation disconnected. I have had it back to Ford for the recall and it still gives the code. I can clear it and it may come back the next day or a week later. Any ideas where to start?
Old May 24, 2019 | 03:16 PM
redford's Avatar
redford
FTE Leadership Emeritus
What engine? What year? What code?
Old May 24, 2019 | 03:27 PM
Edd505's Avatar
Edd505
2015 F350 6.7 PO4DB Crankcase ventilation disconnected - nothings disconnected -yet. 20,0000 more mile before stuff falls off.
Old May 27, 2019 | 06:52 AM
redford's Avatar
redford
Moved to 6.7L PSD engine forum.
Good luck on your repairs.
Old May 27, 2019 | 08:36 AM
senix's Avatar
senix
Take it back for a proper repair. They didn't do something right.
That is what I would do.
Old May 29, 2019 | 07:50 PM
The Bone's Avatar
The Bone
There was a recall on that item. Just take it back because something isn't correct.
Old May 29, 2019 | 08:03 PM
Overkill2's Avatar
Overkill2
I agree with the guys here. I read that there's a sensor on the throttle body connection where the tube connects to it from the CCV box on the valve cover. At least get it right before you delete it if you are.
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
Charles Sweetland
EcoBoost (all engine sizes)
Aug 22, 2016 10:20 PM
mr.fordneck
Dec 7, 2010 03:13 AM
jacaroo
1983 - 2012 Ranger & B-Series
Sep 23, 2004 06:06 PM
MENESLIS
Apr 23, 2004 10:24 AM
