Gauge cluster lights
Old May 22, 2019 | 09:00 PM
Hondo Rubio's Avatar
Hondo Rubio
Gauge cluster lights won’t turn off after the key is removed and no other lights are on and it will drain my battery completely over night need help!!!!!!!
Old May 22, 2019 | 10:40 PM
farmert's Avatar
farmert
It sounds to me that something is back feeding the dash lights. I'd take a look at the headlight switch. If you don't have a trailer tow package, and added a trailer light hookup with one of those premade harnesses that plug into the truck's tail lights back by the rear bumper, it can overheat the light switch and it will melt the wires/switch. This happened to my 90, but the lights would go out unless you had the switch pulled out to between full on and just the park light position. A new switch was the fix for me. If it is bad enough, a new pigtail to the switch is needed.
RoadkingKai
Jun 3, 2018 12:33 AM
Bossdrum
Sep 11, 2012 09:52 PM
crazed87bronco
Nov 8, 2011 04:29 PM
garyodell
1997 - 2003 F150
Feb 28, 2010 03:59 PM
03_PSD
Oct 10, 2009 03:21 PM
