Sponsored by: Real Truck
Need help on brakes
Old May 21, 2019 | 06:49 PM
rmk2001800's Avatar
rmk2001800
Need help on brakes
Ok.... I’ll try to make this short.
2008 f350 6.4
Replaced hydro post, master cylinder, rotors, pads, and calipers. Now I have a soft pedal.
i plugged the master cylinder and the pedal is rock hard.
i have ran about 24 oz through each bleeder with a pressure bleeder.
Cycled the abs 4 times then bleed again.
pedal is still soft?
Any sugeestions?
thanks for the help
Old May 21, 2019 | 08:02 PM
Djosbun's Avatar
Djosbun
Did you bench bleed the master cylinder before installing? They usually come with the required ‘kit’ when you buy one.
I know you have gone through a decent amount of brake fluid since the install but you can’t really bypass bench bleeding and expect a solid pedal.
— Dave
Old May 21, 2019 | 09:41 PM
xd2200's Avatar
xd2200
Also, check each caliper to make sure bleeder is above brake line connection (will be below if left side is installed on right or vice versa.)
Old May 22, 2019 | 06:22 PM
rmk2001800's Avatar
rmk2001800
Yes I bench bleed- also plugged the master cylinder to check for solid pedal and it was.
all bleeders are above the inlet.
I tried to pull the abs fuse today but that didn’t help either.
Old May 22, 2019 | 06:40 PM
Djosbun's Avatar
Djosbun
Try adjusting the rod that goes to the master cylinder. There have been past posts about this and how it resolves a soft pedal.
— Dave
Old May 22, 2019 | 06:42 PM
rmk2001800's Avatar
rmk2001800
I don’t recall an adjustment on the hydro booster-
Old May 22, 2019 | 08:12 PM
leadmic's Avatar
leadmic
Did you activate the auto bleed for the ABS module?
Old May 22, 2019 | 08:44 PM
rmk2001800's Avatar
rmk2001800
Activated 4 times than bleed all brakes afterwards.
Old May 23, 2019 | 09:12 AM
Flaman's Avatar
Flaman
Do the auto bleed some more. It took about 10 times on a GMC I had to get all the air out of the ABS module. You may also want to take the truck to a gravel/sandy road and get the ABS to kick in a few times, then run the auto bleed some more.
Good luck!
Old May 23, 2019 | 10:00 AM
leadmic's Avatar
leadmic
I replaced the front calipers on mine auto blead it several times to no avail. I finally went out with my trailer connected and activated the abs on the street several times to dislodge the air from the ABS. All is good now but I don't know why they are so hard to blee9.
dmueller71
26
Sep 3, 2019 12:53 PM
smokewagun
2009 - 2014 F150
Jul 1, 2019 08:29 PM
IDIDieselJohn
21
Oct 18, 2015 06:38 AM
BigTruk small feet
Oct 13, 2014 07:18 PM
Butch(OH)
Apr 23, 2008 05:14 PM
