I was in my '53 F100. I just replaced it with a different ratio R&P and differential. I used a different carrier for the replacement. I thought my 9 Inch rear was from a '71 Torino. It was in the truck, when I bought it, but the whole drive train was '71 Torino at that time. Except for the axle housing, that drive train has been replaced. Even The axle housing was narrowed. One axle is still original, but shortened. That 3rd member was rebuilt with a 3.25 ratio and Auburn differential in 1998.
The 9's in the cars have right and left specific axle shafts, while the trucks use the same axle shafts right/left.
The car 9's don't fit the trucks very well, because they are different widths, some have rear coil suspension.
1957/72 F100 is the 9" of choice for 1948/52 F1's and 1953/56 F100's.
My axle shafts are right & left specific, but custom lengths, since I narrowed the housing, and tubbed the bed to get 10" wide tires under the bed. I still have leaf springs. 10" wide tires are as wide as I can get without going to coil springs and a 4 bar suspension. I haven't felt the need to do that. My axles are 28 spline. I think some trucks use 31 spline axles.
9 inch: 1957/67 F100 have 28 spline axle shafts. 1968/79 F100, 1975/79 F150 could have 28 or 31 spline axle shafts. 1980/86 F100/150 have 31 spline axle shafts.
