Light issue
Old May 19, 2019 | 12:00 PM
Green7.3's Avatar
Green7.3
Light issue
Hey, so I just bought a 97 f250 7.3 zero rust with just under 150k miles. I am going through fixing little things and I can't figure out the head lights/turn signal/hazards.
So the drivers side will light up all three ( head light and markers/turn signal) but will not blink. The passenger side will only light up the main headlight and not the others but it will blink when I turn the signal/hazard lights on.
I checked the relay on both side's of the fuse board switched the front to the back and the back to the front and its still doing the same thing. I put new bulbs in tried both direction in case it didn't like the way the bulb was sitting and it still doesn't work.
Could the 522's both be a little bad and causing this? Now the rear lights all work turn signals and hazards regardless of what i use.
Could this be a bad socket? All the lights have power one way or the other, could this be a bad signal lever/hazard button?
Getting a little stumped on what I thought would be a simple fix
Thanks for any suggestions
Old May 19, 2019 | 12:41 PM
Green7.3's Avatar
Green7.3
I think i figured it out, all the grounds broke free from the bolts there is one on the driver side and two on the passenger side, does it matter if I bolt the two passenger sides together?
Thanks
Old May 19, 2019 | 02:18 PM
farmert's Avatar
farmert
Thanks
I was thinking bad grounds when I read your first post. It will not matter on if you attach both ground at the same place. bad grounds can do so crazy things.
Old May 19, 2019 | 05:42 PM
Green7.3's Avatar
Green7.3
yeah it was driving me nuts I'd change a bulb then it would work then it would stop then they would all stop working, spent way to long on it
-P
Old May 20, 2019 | 12:11 PM
knottyrope's Avatar
knottyrope
kick panels at the front doors have a ground for the cab inside that gets rusty
skyrader
Electrical Systems/Wiring
Aug 20, 2017 04:12 PM
1978fordf250
Sep 18, 2010 12:36 PM
77-400-4x4
Mar 5, 2007 11:27 AM
70_f100
Mar 6, 2006 12:01 PM
sully_1
Nov 14, 2001 12:00 AM
