replacement wheels?
Old May 18, 2019 | 07:59 PM
Dunderberg's Avatar
Dunderberg
7th Gear
replacement wheels?
I have a 1972 F250 Camper Special with the 8100-lb GVWR. It currently has the 16.5 x 7? stock wheels with decaying old tires.
I need to get new tires pronto, but in 16" size. I was looking in the junkyards for stock wheels, but the 16" ones looked to be only 6" wide,.
This truck will have a 'lightish' camper while hauling a small horse trailer. It will be on dirt roads in the mountains. Are these 16x6 stock wheels up to
handling this weight with E-rated tires? It might be my imagination but the steel seemed a little wimpier than the 16.5s? Thanks for info!
Old May 18, 2019 | 08:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Dunderberg
I have a 1972 F250 Camper Special with the 8100-lb GVWR. It currently has the 16.5" x 6.75" stock wheels with decaying old tires (original size was 8.75" x 16.5").
I need to get new tires pronto, but in 16" size. I was looking in the junkyards for stock wheels, but the 16" ones looked to be only 6" wide.
Are these 16x6 stock wheels up to handling this weight with E-rated tires? It might be my imagination but the steel seemed a little wimpier than the 16.5s? Thanks for info!
1967/72 F350 Camper Specials have the same 16.5" x 6.75" wheels, but the tire size is 9.50" x 16.5." Lotsa luck finding these puppies today.
8 lug wheels on a 6.50" bolt circle: 1948/52 F2/F3; 1953/96 F250; 1967/97 F350; 1969/74 E300; 1975/2014 E250/350; 1997 F250 Heavy Duty.
F250/350's went to metric wheels in 1999, but no Econoline of any year has metric wheels.
Most of these 1980 and later wheels are 16" x 6" but Ford also offered some 1985/86's with 16.5" x 6.75" wheels, which you obviously don't want.
I don't know how wide the 2002/2014 E250/350 wheels are, have no truck parts catalog after 2001.
Look at aftermarket aluminum wheels, I would assume they are available in 7, 8 and 10 inch widths.
Where in CA do you live?
Old May 18, 2019 | 09:34 PM
Dunderberg's Avatar
Dunderberg
7th Gear
This is great info! I hadn't realized the wheels on my truck were not original.
The fact that Ford used the 16x6 steel wheels on the later F350 shows that they are more than stout enough for my use.
This is cool as I did want to retain the stock look (hubcaps). Too bad Ford didn't make a wider 16" to allow bigger tires!
Thanks again! J
Old May 18, 2019 | 11:15 PM
NumberDummy
Thanks again! J
Those hubcaps (stainless and painted versions) were used on 1967/77 F250/350, 1969/74 E300, 1975/77 E250/350.
However, if you need a hubcap or more, your truck has outie wheels, while some 1967/68's have innie wheels. Innie hubcaps will not fit outie wheels and vice versa.
Innie hubcaps are 10 5/16" diameter, while outie hubcaps are 11 3/4" diameter.
Old May 19, 2019 | 05:16 PM
Alex from GA's Avatar
Alex from GA
If you use any of the 16" 8 lug wheels from 72 on through 99 they're plenty strong enough. 235 85r16 tires usually are 10 ply rating and are 31" in diameter. I've been using those on the front of my 68 Camper Special for 30+ years with an overhead camper for most of that.
NZPUMP
Aug 15, 2016 10:02 PM
airforrest
Dec 9, 2012 08:59 AM
66fstbk
Mar 29, 2011 02:10 AM
spunout
Texas Chapter
Jun 21, 2010 03:14 PM
joeskeeter
Dec 20, 2007 06:49 AM
