Dash warnings
Old May 21, 2019 | 05:24 PM
Mud Doc's Avatar
Mud Doc
Got the truck back--turned out to be a speed sensor on front wheel driver side showed 'open', code was c0031. $100 deductible on a $274 bill, + a loaner truck. Southwest Ford did very well on this repair, would recommend anyone in the area to try them for work. They also have a Hunter machine that checks alignment as you drive in--said toe was within spec.
Old May 21, 2019 | 08:32 PM
TeddyD's Avatar
TeddyD
Originally Posted by HRTKD
Post #7, For The Win!!! (Even a blind pig finds an acorn every once in a while)
Glad it's going to be an easy fix.
Damn. I thought my post was going to win this one lol. When it happened to me, I thought it was a wheel sensor and was shocked when it was the BPP switch.
Old May 21, 2019 | 09:10 PM
Mud Doc's Avatar
Mud Doc
The SA told me a lot of the similar problems he had seen were due to the BLIS system in the rear taillights, but turned out not to be the problem.
Old May 25, 2019 | 09:10 PM
Mud Doc's Avatar
Mud Doc
Another thing that was wrong with the dash warnings--the IBC did not work when towing, but the manual lever would. Happy to say replacing the sensor also fixed the IBC problem . Towed about 150 miles today, everything working fine. And the lower settings on the shocks seem much better now--no bottoming on hard bumps.
iamsuperdan
May 20, 2019 07:42 PM
NFAFAN
Jun 1, 2018 12:38 PM
rander44
2009 - 2014 F150
Nov 28, 2012 07:14 PM
rander44
Nov 27, 2012 02:00 PM
