HELP! ABS
Old May 18, 2019 | 06:43 AM
dvcroket's Avatar
dvcroket
HELP! ABS
95 F350 PSD. ABS light flashing on dash...wont go into gear. Had this happen 20 years ago and a Ford tech helped me locate a reset under steering column. Can't find it now. 200 miles from home and need to be back on road soon.
Old May 18, 2019 | 09:21 AM
farmert's Avatar
farmert
Check for a blown fuse in the in cab fuse panel. I had the light come on in my 97 after pulling a trailer with faulty wiring, and a fuse had blown. If I remember right the light was on steady though.
Old May 18, 2019 | 09:57 AM
BuddyBarnes's Avatar
BuddyBarnes
I do not know of a reset button for abs on these trucks. If the truck is not driving or stopping funky you will probably be ok driving home 200 mi. I would take it easy though.
Old May 18, 2019 | 10:01 AM
dvcroket's Avatar
dvcroket
Turns out it was the 50 amp fuse under the hood that feeds 3 positions on the under dash panel. Now just wondering what caused it to blow....had been driving for about 200 miles and not towing anything.
Old May 18, 2019 | 10:15 AM
BuddyBarnes
I am sure you already know that there is a short some where on one of the 3 feeds. Also it could be the fuse just decided to take a dump. Hit any hard pot holes etc ? Farmert " faulty trailer wire " To hitch? - I would take a look there.
Old May 18, 2019 | 10:35 AM
farmert's Avatar
farmert
Section 18-01: Wiring and Circuit Protection
1996 F-150, F-250, F-350, F-Super Duty Chassis Cab, Motorhome Chassis, and Bronco Workshop Manual
DESCRIPTION AND OPERATION
Fuse Junction Panel
Each vehicle has a fuse panel that contains most of the fuses used in the electrical system.
Location
The fuse panels for F-150, F-250, F-350, F-Super Duty Chassis and Bronco are located on the instrument panel behind an access door, left of the steering column. The location of the fuse panel for the Motorhome Stripped Chassis is up to the body builder. The fuse panel for these models is usually located under the instrument panel near the steering column.
Fuse Panel, F-150, F-250, F-350, F-Super Duty and Bronco
ItemPart NumberDescription
114401Wiring Assembly — Main
214401Fuse Panel
314401Wiring Assembly — Main
4—Fuse (3 Amp) DI Diesel
514526Circuit Breaker (20 Amp)
614A254Fuse Panel Bracket
714526Circuit Breaker (20 Amp)
813350Turn Signal Flasher Assembly
9N803876-S424Screw
Content
The following circuit protection charts give the location and values of all the circuits containing fuses or circuit breakers.
Fuse Panel, F-Series and Bronco
Fuse ProtectionAmpsCircuits Protected
130Heater/A/C Blower
230Wiper/Washer
33AIdle Switch (Diesel Only)
415Warning Buzzer/Chime Module, Exterior Lamps, Instrument Illumination, Trailer Exterior Lamp Relay
510Air Bag Restraint
615A/C Clutch, Diesel Aux. Fuel Selector, a Remote Keyless Entry
715Turn Lamps, Rear Window Defrost a
815Courtesy/Dome/Cargo Lamps, Electric Outside Mirrors, Speedometer Memory, Warning Buzzer/Chime Module, Overhead Console (Bronco) Sun Visor Illumination (Bronco)
925Power Point
104Instrument Illumination
1115Radio, Radio Display Dim
1220 C.B.Power Door Locks, Electronic Shift Motor 4WD, Power Lumbar, Tailgate Power Window, Key Switch a , Power Driver Seat (SuperCab Only)
1315Stop/Hazard Lamps, Anti-Lock Brake Module Memory Power (F-Series Only), Speed Control, Stop Sense for: Powertrain Control, Anti-Lock Brakes, Automatic Transmission Shift Interlock
1420 C.B.Power Windows, Tailgate Power Window, Instrument Panel Switch a
1520Anti-Lock Brakes (F-Series Only)
1615Cigar Lighter, Data Link Connector
1710Warning Buzzer/Chime Module, Warning Indicators, Diesel Indicators a , Gauges, Tachometer, Transmission Control Switch
1810Electronic Shift Module 4WD, Speedometer, Air Bag Restraint, Automatic Transmission Shift Interlock, Automatic Day/Night Mirror Overhead Console (Bronco), APCM (Diesel)
a Indicates Diesel or Bronco functions only.
Fuse Panel, F-Super Duty Motorhome Chassis
Fuse PositionAmpsCircuits Protected
1—Not Used
230Windshield Wiper/Washer, Internal Wiper/Washer
3—Not Used
415AInstrument Panel Warning Lamps, PSOM, Warning Chime
520APSOM, Marker Lamps, Instrument Panel Lights Main Light Switch
610ABody Builder Accessory Feed (Accessory and Run)
715ADaytime Running Lamps, Turn Signal Lamp, Overdrive Cancel Switch, Brake Shift Interlock
815ABody Builder Accessory Feed (Run Only)
915Hazard Lamps, Stoplamps, Brake Pressure Switch
10—Not Used
11—Not Used
12—Not Used
135AInstrument Panel Illumination
145ARadio Feed
15—Not Used
16—Not Used
17—Not Used
18—Not Used
Must have been the fuse that powers fuse 5,9,13. Maybe a bare wire going to the tranny?
Old May 20, 2019 | 07:45 PM
dvcroket's Avatar
dvcroket
Had no problems with ABS after replacing the 50 amp fuse under the hood Saturday....until now. Hit a good bump this afternoon and it came back on. Got home and replaced the fuse again...immediately blew when I turned the key back on. According to my manual, the 50 amp feeds positions 5, 9 & 13 under the dash. Position 5 is for air bag (don't have one), 9 is power point, & 13 is anti lock brakes, brake shift interlock, electronic engine control, speed control, stop/hazard lamps, stop sense for electronic engine control. Where do I start trying to locate the source of the short? Especially since fuse blows after replacing as soon as I cycle key back on.
I have what I thought to be a separate issue but wonder if they are somehow related. Last week I had a couple of episodes where the truck died backing out of the driveway and a couple of times taking off from a stoplight....always seemed to happen when taking off after parked or stopped. Then when I was on the road for about 400 miles Friday, several times while driving at highway speed, the engine would hesitate a split second, the wait to start light flash once, and the volt meter would twitch until the GPR completed it's cycle then return back to normal. This happened several times during that road trip but the ABS issue came at the very end but not directly associated with the other issue that I could tell. In today's scenario, I hit the bump, the engine hesitated, the wait to start light flashed, then maybe 5-10 seconds later the ABS light started flashing.
Old May 21, 2019 | 08:43 AM
z31freakify's Avatar
z31freakify
Check your E- brake signal cable it might be shorting out.
fixitman1310
Mar 20, 2011 10:15 AM
JesterPgh
16
Mar 1, 2009 09:42 AM
straightsixer
Feb 1, 2008 08:02 PM
BURNSTOUGHFORD
1997 - 2003 F150
May 6, 2007 11:44 AM
