Bad ground?
Old Oct 3, 2003 | 12:39 PM
dotcentral's Avatar
dotcentral
Question Bad ground?
Went to pop the hood the other day with the engine running. Got a pretty good shock. I am almost certain I need to check my grounds as some of the gauges and interior lights are sort of hit or miss. What would have caused the shock? A bad ground at the block? Would like to take care of this one pretty quick. Thanks.
Old Oct 3, 2003 | 01:14 PM
socaljerry's Avatar
socaljerry
It could be, I would also check for an ignition short. Such as a coil wire or maybe sparkplug wires. These could cause you vehicle to miss and run rough. They also pack quite a punch!
Old Oct 4, 2003 | 04:38 AM
willowbilly3's Avatar
willowbilly3
You can't have too many grounds. You need them from the engine to frame and engine to cab, I have seen guys leave them off and have all sorts of problems. One of the better ones was a guy who put his battery ground to the frame and ended up frying the speedo cable because that was the path the power took when he cranked it. He had actually got by for quite a while until cold weather came and he flooded it which required alot of excessive cranking.
Old Oct 4, 2003 | 07:48 AM
rmt's Avatar
rmt
wb3 is right on. If you have bad grounds all sorts of odd things can happen. Things that seem impossible as well as impossible to fix. Don't assume just because you see the wire or strap hooked up that it's working. Be sure you have clean metal to metal contact.
Old Oct 4, 2003 | 01:27 PM
Mike W's Avatar
Mike W
Put a ground strap on your hood. Maybe it was just static electricity.
Adam Jones
Sep 7, 2015 12:59 PM
blazer1620
1983 - 2012 Ranger & B-Series
Oct 4, 2014 07:47 AM
Cowboy9215
Jun 19, 2014 10:02 PM
Badboy4wd
Feb 21, 2014 09:57 PM
