Racks
Old May 17, 2019 | 08:06 PM
Section179's Avatar
Section179
Hackenbush,
can you get the panel to fold up against the bakrak? I quite often run my bakflip folded all the way up to get full use of the bed. That’s my main concern with a rack.
Old May 17, 2019 | 09:31 PM
Txwhitetailhunter's Avatar
Txwhitetailhunter
I originally built this one myself in ‘08 or ‘09 for my then F150. I had to revamp it to fit the Super Duty. It is cab height and solid as a rock. It is tied down at the stake pockets. I used steelbuilding Z pearlings to make the light bar and louvers, 2” box tubing for the verticals and side rails. The Magnum racks are nice if you are looking to purchase a factory built one.
Old May 18, 2019 | 04:39 AM
user 474747383's Avatar
user 474747383
Originally Posted by Section179
Hackenbush,
I haven't tried the Back Flip MX4 but the Bak Flip Revolver has plenty of room, Should be the same as long as it's inside the bed rail. I'd call them just to be sure. There great to work with.
It's also easy on and off in 10 min.
https://backrack.ca/tonneau-cover-adaptors.html
Old May 18, 2019 | 11:35 AM
ccie7879's Avatar
ccie7879
I have a "Backrack" with a Bak Flip MX4 on an 8' bed. You need to order the spacer kit so the Backrack sits about an inch off the bed rails. I am able to fold the Bak Flip all the way up against the Backrack (full open). The bak flip braces that hold it up against the window/Backrack are too long so you need to shorted them or use a bungee to strap the Bak Flip full open.
Old May 18, 2019 | 03:04 PM
user 474747383
I discarded the 1" spacers and used the 1" shorter standard pocket bolts to keep it lower, does not affect the covert all. But you still need the side plates that come in the kit with the spacer as they don't wrap around the inside of the bed rail..
Old May 20, 2019 | 07:47 PM
mnscruff's Avatar
mnscruff
Spyder Industries custom rack
Old May 20, 2019 | 08:37 PM
Brent376's Avatar
Brent376
That is pretty Kewl
Old May 23, 2019 | 07:04 PM
mattymax's Avatar
mattymax
Anyone have a picture of a low profile without a tool box ?
mat
Old May 25, 2019 | 01:17 AM
Brent376's Avatar
Brent376
Thanks everyone for the input. I have decided on the Magnum and ordered the Sportrack. I will post pics on arrival.
18SD_Lariat
Dec 7, 2018 01:03 PM
runawayhound
Jan 13, 2016 04:15 PM
Flawless_X
Apr 8, 2012 10:15 AM
Snowking
29
Jan 2, 2010 10:07 PM
flyingphish
6.4L Power Stroke Diesel
32
Mar 20, 2007 03:23 PM
