Looking to buy a new F-150
I am looking at buying a new truck. I have a travel 28 foot long trailer that I am going to tow, the dry weight is 6500 lbs. I want the truck to have trailer brakes and enough towing capacity to pull the trailer and all of our camping stuff. I live in Colorado, so going up hills will also be a factor in making my decision. From what I can tell the F-150 has the best towing capacity, what package would best fit my towing needs, I will also be using this as my daily driver to and from work. Should I stick with the F-150 or go with the F-250?? I have a few months to decide. Thanks for any input or advise.
The attached gives you all sorts of objective info. It’s for 2017, but it should be relevant for most recent years.
https://www.fleet.ford.com/resources...de_r6_Nov8.pdf
I find in general with equipment that it’s always better to have too capacity/capability vs just enough and ending up wanting more
You’d better be careful. Payload runs out well before towing capacity.
What cab configuration? Supercrew eats payload.
What trim level? Options deduct capacity.
Do you expect to use the bed for gear?
Your proper tongue weight should be between 650 and 975 pounds, but loaded Im betting close to 1,000 pounds. In a Loaded supercrew, that leaves barely a few hundred pounds for wood, cooler, etc. Sound goofy? Been there many times.
In my experience and in your local, I’d opt for a 250, and forget the tail wagging the dog.
Your hitch weight is low, probably more likely to be 850 lbs. Add in 800 lbs for family and you are at or above max of payload for many configurations.
Better to be safe.
