92 fuel pump plug
Old May 15, 2019 | 11:32 AM
showle1's Avatar
showle1
92 fuel pump plug
Hey guys I have a 92 f150 with the dual tanks and both fuel tanks are shot, leaking etc and neither fuel pump works so I found a guy selling two tanks from a truck that both worked great in. problem is the plugs are different, does anyone happen to know the best way to make pigtails that would work? I have the wiring harness off of the donor truck too . Thanks
Old May 15, 2019 | 11:42 AM
rla2005's Avatar
rla2005
What year/model/engine is the donor truck?
Old May 16, 2019 | 01:49 PM
showle1's Avatar
showle1
the donor is a 94 same both are 150's with the 302.
Old May 16, 2019 | 04:08 PM
rla2005's Avatar
rla2005
The wire colors should be the same. Cut-off the old plug then solder and heat shrink the newer connector onto the existing wires.
Mike_Smith460
Apr 19, 2014 10:03 AM
nicksorenson
Jul 4, 2009 12:03 PM
nd4spd
Feb 21, 2004 01:48 PM
