What mod next?
Old Oct 3, 2003 | 11:25 AM
forddytube's Avatar
forddytube
Question i got shorty headers, tru duals and flowys, cold air intake,and a superchip, what nex
what more can i do to my truck to pickup more horses?i have a 1991 f-150 351w, 5.8l v8, she has headers, tru duals and flowmaster 40 series, relocated intake snorkel and a superchip.
i wana know where can i pickup more horses and how do i get to install a hood scoop that really works.is there a way to make a ram air system or change something on the truck to have a working ram air system.
thank you
F.T.E. rules!!!!!
Old Oct 3, 2003 | 01:15 PM
Vanhecht's Avatar
Vanhecht
underdrive pulleys...higher pressure fuel injectors...msd type ignition...
Old Oct 3, 2003 | 04:12 PM
Hit Man X's Avatar
Hit Man X
Well Magnaflows make more power.
ASP Underdrive pullies are good for 8-12rwhp
Get an adj fuel regulator
MSD seems to give better throttle response down low, not too much power gains.
Stock 351W intake manifold sucks, get you an Edelbrock. .
Electric Fans
Old Oct 3, 2003 | 04:53 PM
forddytube's Avatar
forddytube
i like the 40 sereis flowmasters ,you should hear them without cats!! boy......
what do underdrive pulleys do and how do they work?
what about the working ram air system,i still don't understand why i can't do this on my 1991 f-150 351w 5.8l automatic trans e40d..
i have ordered an edlebrok intake mani cause i need to get new upper and lower intake gaskets ,i also got the high pressure injectors.
i mainlly want a working ram system...how?????.
Old Oct 3, 2003 | 05:10 PM
Hit Man X's Avatar
Hit Man X
I hear 40 Series Flows with no cats all time ... Mustangs are here everywhere.
Underdrive pullies replace the crank, waterpump, and alternator pulleys for more power. They are easy to install with air tools in about 1 hour. You'll get LOTS of mixed reviews about them but I have run mine for close to two years with no problems. ASP is the way to go.
Get you a TransGo shift kit in your E4OD and a mild 2400rpm stall converter will get you out of the hole a lot faster.
Ram Air is pretty gimmicky...I don't see it adding any substancial power with the cost of it.
Old Oct 7, 2003 | 02:28 AM
sadcad's Avatar
sadcad
i have a 93 f150 and plan to do the same combos as you. sounds like your happy with it. im curious to know how much hp do you think you have gotten and if you get better mpg...thanks
you might want steeper gears out back for quicker acceleration...
Old Oct 7, 2003 | 09:26 AM
forddytube's Avatar
forddytube
hey sadcad ,i am happy with the performance of the truck, so happy i provoke ****'s to race at stop lights.
mpg is isn't very good i guess it's cuase the chip sets everything,(gas, ignition, etc)higher(more gas more power).but overall i find that i don't have to beat the truck down to pass nobody, she shifts alot firmer and takes off real nice.
people have told me before that in order to get more ponies u'll have to use more gas.
i know if you go ahead with the similar mods u'll love what your truck will feel like ,trust me!
Old Oct 7, 2003 | 02:33 PM
MustangGT221's Avatar
MustangGT221
I have ram air (check gallery) doesn't add much for power, but it makes the truck sound 10 times better.
Old Oct 7, 2003 | 04:26 PM
forddytube's Avatar
forddytube
mustanggt221 ,do you have any idea how my 1991 351w v8 5.8L auto trans e40d can have a functional ram system. i hear diferent stuff about mass air sensors and stuff like that, that wont allow a working ram system . any idea on what i got to do?, getting a hood should'nt be a problem i need to know what i have to change in order to fool the computer to make use of the rammed air instead of controlling it..better sound works for me .
i like your truck bro,clean like my 91 and has the same exhaust setup only i have 5"tips.
Old Oct 7, 2003 | 06:44 PM
chuckman's Avatar
chuckman
your 91 doesnt have a mass air sensor, so dont worry about that. besides which, even if you did, the chip would be able to worry about it.
if youre really into it, throw on a good set of heads. might be able to find some GT40s decently "cheap." port em yourself for some more flow on the cheap. combine it with a decent intake, and you should have a good strong motor.
Old Oct 7, 2003 | 11:42 PM
forddytube's Avatar
forddytube
these gt40's you speak of chuckman ,what type of truck do i get them outa,cause we only have one reckers yard here and they don't have to much stuff.and also is there anything like measurements ,size etc that i should be looking for or is GT40'S enough.
Old Oct 8, 2003 | 03:15 PM
borin&strokin's Avatar
borin&strokin
sounds like a cam, and a reburn on the superchip would give you the most bang for the buck. Don't get to radical, and you will LOVE it. Then intake and heads. Skip the ram air. Won't do CRAP for power.
Old Oct 8, 2003 | 03:34 PM
chuckman's Avatar
chuckman
gt 40s, IIRC, and i havent really looked at too much v8 stuff lately, came on the 1st gen lightnings and 93+ cobras with teh 5.0. i think explorers came with a version of them as well, the gt40p, which might work on the windsor, not sure, im more of a I6 guy who wants a stang......
Old Oct 8, 2003 | 05:08 PM
forddytube's Avatar
forddytube
i too would love a stang bro. i am looking to keep this motor and maybe drop it in a light body like a morris minor or my 1965 ford ranch wagon, i have a thing for the curves on older cars and trucks ,much like areal woman. check out my gallery and see the old Morris Minor of England i wana rod up some day with a 351w
