1978 - 1996 Big Bronco
AC/Heater
Old Oct 3, 2003 | 11:17 AM
rjk666's Avatar
rjk666
AC/Heater
Have any of you heard of this. My 91 stock bronco has a strange prob with the ac/heater. when Iturn in on to blow out of the vents it is fine, when I start driving and get over about 40 mph it starts blowing out of the defroster, when I slow down it start blowing out of the vents agian. Any help would be great.
Old Oct 3, 2003 | 11:50 AM
fcarruth's Avatar
fcarruth
Sounds like a vacuum problem to me. Mine did the same thing when I had it on MAX. Check the creme color hose on the passenger side near the firewall coming off the small motor. Mine was bad at this place only and took care of my problems. I just got a small piece of hose and cut the old out and then put the new in with heat shrink tape and then put a vacuum gauge on it and it didn't drop at all. You could also attach it with a larger size hose with the smaller fitting inside.
Good luck.
tap1946
Nov 28, 2017 12:19 PM
jls8814
Jul 12, 2015 08:38 PM
MorrisClan
May 14, 2015 05:36 PM
P7M8
Mar 24, 2013 02:37 PM
smokeyb97
18
Oct 31, 2010 06:26 AM
