AC/Heater fuse blowing on high
79 F100, w/factory AC, fuse blows on high setting only. I replaced the blower motor when it quit some time ago. The fuse would blow on high even when the old blower motor worked. This is the only electrical issue I have, but I would like to solve this problem considering how weak these motors blow on low and medium. Any suggestions on what to check?
Thanks, I meant to add that I replaced the switch, too. The wire going to the high connection shows signs it has been getting hot.
An amp meter will tell you how hi of a current draw you are pulling, if your blower is pulling lets say 35 amps on high speed, your 30 amp fuse will blow fairly quick, if you have a short in the motor it should trip right away, is your system blowing the fuse pretty fast?
I,ve seen two speed motors work on low speed and short out on high speed
I'll check those wires, too.
I'll check the amp output and the high speed wire. Thanks
