New Intermediate Steering Shaft
Old May 14, 2019 | 12:13 PM
woodson84's Avatar
woodson84
On the truck I just bought, the intermediate steering shaft (the part between the steering column and gear box that has the 2 u-joints and takes up the movement from the suspension) is clapped out.
There's easily a quarter turn of play in between the two sections that are meant to take up the movement of the suspension.
Easy enough right? We yeah except I can't find the part! I haven't called the dealership yet but so far this is the only part I have found:
https://www.summitracing.com/parts/brg-000985
$250 seems steep as well. Can these be rebuilt? Where can I look.
1990 Ford F-250 XLT Lariat 7.5L 4x4
Old May 14, 2019 | 12:19 PM
woodson84's Avatar
woodson84
Sorry, I have also found more expensive options: https://www.carid.com/flaming-river/...97&url=3175917
Old May 14, 2019 | 12:33 PM
timbersteel's Avatar
timbersteel
Dorman makes an exact replacement. Though it ranges from $280-400 depending on where you buy it.
The Borgenson shaft has to be cut to length....
The Flaming River may need to be as well....
Old May 14, 2019 | 12:58 PM
woodson84's Avatar
woodson84
I see the Dorman for other years but not for 1990. Unfortunately i'm not sure which ones from other years would be compatible.
Old May 14, 2019 | 01:03 PM
timbersteel
All '87-96 F series and higher have the same Intermediate steering shaft that connects from the steering gearbox to the column through the firewall.
Someone can correct me, but I'm not aware of any different type.
I went to the junkyard and pulled one for $25. They all liked identical from '87 and up.
Old May 14, 2019 | 04:46 PM
GNR22's Avatar
GNR22
The 87 to 91 is a totally different style than the 92 to 96/7. I have the Borgeson shaft on one of my trucks. Had to cut a ton of length off to make it fit, but it works fine.
Old May 14, 2019 | 05:05 PM
timbersteel
Well darn! I thought they were identical from '87-96.
Ok, well, that cleared that up.
Old May 17, 2019 | 05:01 PM
woodson84's Avatar
woodson84
Not totally positive this is correct yet but I found this part number by calling the dealer: E8TZ3B676A
Also found an old thread about it:
https://www.ford-trucks.com/forums/8...ing-shaft.html
Someone mentioned this site:
Truck Parts and Truck Accessories
Looks good but still $250
shrekau
Mar 23, 2014 12:44 PM
cabloom300
Mar 20, 2014 06:33 AM
stryder
Dec 23, 2004 02:01 PM
