Cooling system advice
Old May 12, 2019 | 11:35 PM
John89's Avatar
John89
I am working on a 78 with the 300. My question is should I replace the water pump and outlet tube since they are original and new ones are pretty cheap?
There isn't a problem with the originals, (outlet tube was a little crusty when I replaced hoses) but eventually I will have to drain and pull the radiator to replace the core support bushings.
Thanks in advance.
Old May 13, 2019 | 12:23 AM
hail destroyer's Avatar
hail destroyer
Thanks in advance.
I'd say do it, the original is over 40 years old, no sense in waiting for it to fail after you have it all back together. I'd go with a napa heavy duty unit. I wouldn't use the cheap auto zone/advance/schucks/kragen/0reillys stuff
Old May 13, 2019 | 05:02 AM
Mark8man's Avatar
Mark8man
Yes replacing water pump of an unknown age is good idea and one less thing to fail unexpectedly down the road. Just be sure to pay up and get the highest quality pump you can find.
Old May 13, 2019 | 08:59 AM
Meridian_Mike's Avatar
Meridian_Mike
X3.....
At least that is what I have ALWAYS done..... if you in there .... go on and do it.
Mike
Old May 13, 2019 | 09:20 AM
John89's Avatar
John89
Thanks for the input. Sometimes I get caught up in the "might as well" theory a little too much.
One other question:
Does my pump have a clutch? This doesn't look like what I see in the parts catalogs.
Old May 13, 2019 | 09:24 AM
Meridian_Mike
Pumps don't have a clutch.... Sometimes a fan will but yours doesn't
Plain Jane...
Rusty_S
Apr 3, 2013 10:18 AM
Schuyles
20
Mar 31, 2012 08:08 AM
SideWinder4.9l
Nov 29, 2010 12:36 AM
The79Beast
Jul 24, 2009 11:35 PM
weldboy
Nov 4, 2004 07:29 PM
