So my '77 351M broke down on the highway coming home from work last week and I finally got a chance to look at it today. Figured it was the timing chain/sprockets but found this. Any ideas of what would cause this before I replace the chintzy napa reman distributor with the big buck duraspark distributor I've been sitting on? Don't want to besmirch the expensive one if I can avoid it.
Last year I replaced the original distributor with a napa reman because the original's vacuum advance was rusted solid......but it still ran. Stabbed that napa reman and it drove almost 3 miles and the shaft broke in half. Got THIS reman and now the gear teeth are kaput about 400 miles later! What the fork!!!!
Was actually 11/6/2018 I got this reman distributor (just found the receipt). So in 6 months and only a couple hundred miles it's dead? I only drove it to work and back at most maybe 6 times. 35ish miles one way.
if your cam is stock I'd check out the gear on it as best you can and make sure it's not toast then put an MSD gear on your distributor. if your cam is a roller you need a hardened steel or bronze gear.
Even the Chinese junk should last longer than that. hopefully a new gear will fix it but it would suggest you have other problems.
Well without holding the cam in my hands to verify the lobe profiles I'm gonna assume it's stock because I don't see any lifter keepers or anything down there by the lifters. Also found that #1 intake lifter looks to be toast rocker is flopping like a mackerel. With the pressure off the pushrod, I can slip .160" worth of feeler gauges under it. Yippeee. It'll pump up tight with a drill spinning the oil pump rod but as soon as stop the drill, it goes soft again. I'm thinking the crappy oil pressure wasn't getting oil to the dizzy gear. Can I possibly drill a small hole in that oil gallery plug right above the dizzy gear to get more oil to it or would that lower my oil pressure too much?
It was not uncommon for dizzy gears to chip, didn't matter if it was an I-4, I-6, V6 or V8. Chip happens!
Originally the roll pin to retain the gear to the shaft was split, had to be driven in. Later Ford replaced it with a pin w/a head on one end. You could install it with your fingers.
That pin worked loose causing the gear to wobble on the shaft. Didn't take too long after this occurred for the gear to chip.
And there are different gears, 1977/79 F100/350 351M/400 used this puppy: C4TZ-12390-A
But a 351M/400 dizzy bought in an auto parts store may use a different gear.
type of cam has nothing to do with distributor drive gear wear, assuming proper match of materials. the cam drives the distributor. the only load on the distributor is the bushings and of course the oil pump. pull the shaft and check the top bushing.
Whatever distributor you put in, you should always check the position of it's gear. Too many verables to deal with when your dealing in thousandth of a inch. Too far down on the shaft and the cam and block will end up junk. It's a very important step in changing distributors.
