Is Lead Replacement Necessary?
I have just bought a 1969 F100 with the 360 CID engine. I haven't driven a pre-unleaded engine in decades -- do we need to add a lead-replacement product to our fuel to avoid harming the valve seats, etc in these older engines?
Also, any 'heads-up' issues I ought to have firmly in view with the 360 engine? Special care? Specific weaknesses to protect against? Any particular benefits?
TIA,
Dennis
Hardened seats eliminate the need.
Most stuff now is a per-tank bottle, which to my mind gets expensive quickly. However, not so expensive as a valve job!
I have not had to use it in years due to having modern heads, but like the others have said, it's a fairly important item.
Not sure how hard you drove yours Yellow Truck, but I had always heard that if you just putted around town you would get a lot more miles out of the seats than if you were revving up all the time. So if traveling on the highways is your thing, you could be good for awhile.
But they will eventually all do the same thing.
Paul
I've been a little too keen to believe what I have read online in the past and have bought into the doom and gloom that seems to be on the internet. I'm more inclined now to try things & see what the results leave me with in my own experience.
That being said, I drove a '69 302 Ranchero quite a bit between my junior & senior years of high school on 89 octane ethanol fuel with 14* of initial timing. You better believe I didn't have the money for ZDDP oil, lead additive or octane booster. I had to turn the idle up fairly high in gear to 'cover up' the low compression from cylinders 6 & 7 where the head gasket was blown out. Did I suffer catastrophic engine failure or instantly plug up my fuel system? No, not at all. In fact, it ran great, always started and was happy to run out at 70mph on the highway, day in day on in no matter the temperature.
Later when I tore into the engine to address the low compression, I found I had two or three valves with varying amounts of burn-age on them. The seats weren't hammered into the head like some guarantee will happen. They were sunken about how you'd expect for a 50 year old engine that had been used all its life. The short block hadn't been opened, but the guides had been replaced in the heads at some point and they were worn out again by the time I got to them. The main, rod and cam bearings looked worn but not wiped out by any means. The cam & lifters were perfect.
I do now use either Brad Penn, Joe Gibbs or Valvoline racing oils for the extra protection and I also use the highest octane ethanol free fuel I can find (this I do recommend, I'm sure we're all aware how poor quality gasoline is nowadays). I do not use octane booster or lead additive. I sleep just fine at night this way. Even if I do develop a problem, I won't sweat it. I don't rely on my 50 year old vehicles to get me to work everyday and it's only nuts, bolts & money to fix these old rigs. I don't beat on my original engines as I think this is just silly...
Not trying to change any minds, just offering my perspective for others to consider.
Good luck with your truck & be safe!
-Mike
And actually, I may be incorrect on this next point, but I don't expect even a 50 year old engine to have recessed valve seats from normal use. None of mine ever had valve seat issues back in the day, whether they were sixties engines, or had been refurbed. Burned and busted valves, yes. But no recessions.
I had heard that Ford had used induction-hardened seats before '72, but I can't confirm that. I was told by the machinist that did the valve job on my '71 that they were hardened seats. But that's close enough to '72 as to be a possible running change I suppose.
Then again, it did need that valve job at only 100k miles too. Apparently not from seat recession though, from what I was told. So hard to say what was going on. Was it my additives at work, but the prior few years of abuse without it to blame? A hard life by the commercial (a Montana hunting club) previous owner? No way to tell.
Montana may have had leaded fuel all that time too?
Anyway, not saying for sure that your information and experiences are incorrect. Just that we've been dealing with valve recession from lack of lead in the gasoline from a time LONG before the internet was a thing.
Yep, magazines, machinists and other experts could be wrong too, and maybe it was all Y2K-ish gloom-n-doom thinking. But a lot of heads were trashed after lead went away and a lot of cams were thrashed after zinc was reduced in oil. So it might have been total coincidence (I do actually believe in coincidences by the way), but the old info has worked for me.
Paul
Paul
Great input by 1TonBasecamp!
With this said, what grade octane would you run in my 1971 F250 that is used for light / empty load drives around town with a few 3-5 freeway trips of 10 miles or less. Only put 1550 miles on the truck last year.
Paul
Your motor may prefer pure gasoline for reasons related to the seals, fuel lines, and gaskets used, but if it is an I-6 it shouldn't care about octane. The fact it was just rebuild doesn't indicate hardened seats - that is a more expensive option that many people don't choose.
TIA,
Dennis
Lots of these engines run fine for years on unleaded. Are you going to work yours hard? Tow, haul etc? The harder the engine works, the greater the chance you will have valve issues due to the lack of lead.
Even "in the day" a burned valve was not a surprise, even under 100,000 miles. (our '66, 41000 miles for a burned valve)
As to the 360, it is a low compression, sunken piston engine that lasts a long time, burns a lot of gas, and makes modest power.
As an added feature, Ford neoprene umbrella valve seals start to crack and break on the drive home from the new vehicle dealer. So, you might be getting a touch of valve and upper cylinder lube already. Do you get a blue puff or cloud on start up?
