Last fall the local DOT used the wrong oil when chip sealing the local highway. So everytime I drove that highway my truck got covered in a oil / tar splatter that makes the paint feel like its grip tape. Despite washing the truck 1-2 times a week all winter this stuff is stuck on. You guys got any ideas on what to use to remove it without damaging the paint? A local detail shop wanted $450 to use a steam pressure washer on it... seems excessive.
There are a lot of "Tar and Bug" removers available anywhere that sells car wash/detailing stuff.
WD-40 works decent, as does rubbing alcohol.
The key to all these, are to soak a rag (or the area on the truck) and let it "soak" into the tar before scrubbing it off.
If you have any chunks of tar...you can use a plastic scraper (I use an old credit card/gift card) to scrape the majority of it off before using the above methods.
In the past 5-6 years, our county has cheaped out and started tar & graveling ALL the county roads in my area. I HATE THE STUFF! I can't tell you how angry I am every time I turn onto a road I need to travel and see the "Loose Gravel" construction signs. I also ride my motorcycle when I can...and when they do my road, that's 2 months that I can't ride! Grrrr!
Look up CarPro TarX, Should do the trick as it will dissolve/loosen whatever is on there. Make sure to follow directions.
You will want to clay, polish and wax after or whatever you do to protect your paint.
I would not use Diesel, Kerosene, Gas and type of fuel on the paint. Can make it worse if not careful....
I have used it literally dozens of times with no affect to the paint at all. Just make sure to wax the paint after. The new clear coats are very durable.
