What could the problem be
Old May 8, 2019 | 03:40 PM
Zachary Noles's Avatar
Zachary Noles
So I was driving my 1986 Ford F-150 5.0 fuel injected down the road and it just cut off after sputtering for a little while. It wouldn’t crank back so I went and got some gas and put it in the truck. That didn’t work so I bought a coil for it. It still won’t crank. I’m thinking it could be my distributer but not sure. Can anyone tell me what else it could be? Thanks in advance
Old May 8, 2019 | 05:09 PM
Franklin2's Avatar
Franklin2
You will have to stop and do some troubleshooting. You can go by Harbor Freight and get their spark tester. Unplug one of the sparkplug wires and insert the tester and then get someone to watch it as you crank it over. If you have spark, then you must not have fuel. If you do not have spark, then you know to keep going down that trail.
Too many things it could be to start guessing and replacing stuff. Troubleshoot first.
Old May 8, 2019 | 05:10 PM
Franklin2's Avatar
Franklin2
Here's what their spark tester looks like.
Old May 8, 2019 | 05:20 PM
kr98664's Avatar
kr98664
Please define "won't crank".
Does that mean the starter won't do.anything? Or does the starter engage and spin the crankshaft normally (typically known as "cranking") but the engine won't run on its own?
allentown09
Jul 16, 2018 01:14 PM
BeaverPI
21
Sep 5, 2017 06:14 PM
broncoboy20
1978 - 1996 Big Bronco
18
Jun 17, 2013 12:49 AM
flaniganjasonl93
16
Dec 7, 2012 07:44 AM
Diesel_Brad
Nov 27, 2011 01:03 PM
