Bronco II Ford Bronco II
85 2.9l v6 help
Old May 7, 2019 | 08:41 AM
Parker Andrews's Avatar
Parker Andrews
85 2.9l v6 help
i recently acquired two bronco II's. one is 85 2wd automatic that has been rolled but is a running truck with a good motor and trans. the second is a 84 5speed 4x4 but the motor is locked. im looking to pull the running 2.6 from the 85 and put it in the 84. the trucks have the same motor. they are actually only several months apart. i need some direction/info on some how to's on pulling and re-installing the motor. any and all help is greatly appreciated.
Old May 14, 2019 | 07:22 PM
f5fordgirl's Avatar
f5fordgirl
The header says 2.9. your post says 2.6, but I believe you've got a 2.8, mechanical parts should be simple to swap, there may be some wires that were changed between the two years, the carb may also be different.
Samsn4
Ford Truck Parts for Sale
Jul 29, 2013 09:17 PM
Butl85
Bronco II
Oct 24, 2012 09:35 AM
84bronc2
1983 - 2012 Ranger & B-Series
Feb 12, 2009 01:13 PM
msuforeman
Engine Swaps
Sep 8, 2004 07:22 AM
rwahlers
Bronco II
Jul 8, 2002 11:55 AM
