Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Disabling 2014 Escape
Old May 4, 2019 | 03:00 PM
rtf505's Avatar
rtf505
Mom's getting up in years and isn't supposed to be driving, and she hasn't, yet. Is there a simple way, other than taking away her keys, to disable a 2014 Escape were it won't start, but were it can be put back into service when needed. It's still driven by caretakers, etc, so I would prefer not to have to reconnect the battery and reset all the electronics that disconnecting the power would cause. Is there a "starter breaker" or something similar, that could be pulled and not foul up everything?
Any help is appreciated. . .
Old May 4, 2019 | 06:18 PM
projectSHO89's Avatar
projectSHO89
There are a number of potential components that will prevent starting:
BJB Fuse F13
BJB Starter relay
BCM Fuse F78
BCM Fuse F12
There are more, those are just the first few I came across.
Personally, if I had to do this so it had minimal impact on the rest of the drivers, I'd pull fuse F78 and install in its place a fused pigtail with a normally open push-button switch mounted under the dash where it's accessible by someone who is aware of it and can push the button while attempting to start the engine.
Old May 5, 2019 | 07:29 PM
simonsi's Avatar
simonsi
Give her a non-transponder valet key.
Old May 7, 2019 | 04:15 AM
SCUDDOG's Avatar
SCUDDOG
Ford offers "My Key".... check out the manual to see exactly what this does. I've never checked into it. It's designed for teens etc...
Old May 7, 2019 | 06:08 AM
projectSHO89
MyKey won't do it. That feature is for limiting how the vehicle can be operated, not preventing vehicle operation.
Old May 15, 2019 | 04:26 AM
Rovernut's Avatar
Rovernut
That should work, provided the caretaker has 7 foot arms.
I wouldn't suggest doing anything that would be a safety hazard, i.e, anything that would make the car require any task to start it again once it's running.
Pulling something like the fuel pump fuse would be the easiest and safest. Just be sure you have a puller for it because they can be difficult to get out.
And a couple of spares of the right amperage in case they drop it and can't find it or break it.
Old May 15, 2019 | 06:01 AM
projectSHO89
Use 7' of wire and put the switch under the dash near the column. Doh!
Old May 15, 2019 | 08:47 AM
scott91370's Avatar
scott91370
Originally Posted by Rovernut
i.e, anything that would make the car require any task to start it again once it's running..
Why start it if it is already running?
Old May 15, 2019 | 09:21 AM
Rovernut's Avatar
Rovernut
Yeah, I guess that would work. But since you said "pigtail" that's what I was picturing.
LOL ok, yeah, poorly worded.
"...start it again once it's running if it stalls in a bad spot."
TNasty513
Aug 8, 2018 05:09 PM
powrstrkr
25
Apr 2, 2008 10:21 PM
is300wrx
2004 - 2008 F150
Dec 10, 2007 01:58 PM
LASTDON76
1997 - 2003 F150
May 16, 2006 08:16 AM
bradd
Modular V8 (4.6L, 5.4L)
Dec 30, 2003 12:47 PM
