zf5 swap problems
Old May 4, 2019 | 02:07 PM
donovan1234's Avatar
donovan1234
zf5 swap problems
Hello everyone,
I swapped in a zf5 in place of my e4od in my 1990 crew cab. I rebuilt the 460 in it and also swapped in a dana 50 front axle and bw 1345 transfer case cuz hey why not have a 4x4. I am using the auto ecm because it should allow it to at least start.
problem Im having now is it wont start. starter not moving at all.
things I've done:
1. crossed the wires for the neutral safety switch.
2. checked fuses.
3. bench tested the starter and dont get anything from it then either, tested 2 brand new ones and same story.
4. swapped in a new starter relay. I get 6 volts to the sender wire but it doesnt actually send the 12 volts to the starter side. ( I had all these parts laying around so we arent doing a throw money at it type solution)
5. Only interesting thing it does is when I turn the key it makes the sound for the starter to engage. then all the cab lights cut to half bright and the radio turns off. If I disconnect the battery there is a pop from around the engine relays and when I reconnect the battery the post is hot but everything works again. I checked for grounded wires and nothing.
Any ideas? p.s Lets try to avoid the throw money and parts to solve it.
Old May 26, 2019 | 10:17 AM
donovan1234
Figured it out. One of the starters tested bad.
the other starter was grounding through the cable.
Anyone who has a similar issue. CHECK YOUR CABLES!!!
96broncoXlt
1978 - 1996 Big Bronco
15
Nov 27, 2012 12:37 AM
Meilichios
Electrical Systems/Wiring
Jun 28, 2005 12:32 PM
Frank Lang
15
Aug 29, 2004 10:19 PM
69mustang
Aug 2, 2004 03:42 PM
mooner
Jan 1, 2003 04:50 PM
